BlackBox Y2 Moving only positive
Discussion in 'Controller Boards' started by Makoto cameron, Nov 27, 2020.
  1. Makoto cameron
    aloha
    I just purchased and assembled the lead 1010, while testing the movement and jogging the machine z works fine as well as x, but when I move on the y axis they both move + fine but when I try to move - the right side (y) moves correctly but the left (y2) only move + so the gantry twists. I double checked the wiring on both the motors and to the controller board and are correct- yellow green blue red. I also switched motors from side to side and same issue the Y2 motors only goes +. any ideas what could be wrong
    #1 Makoto cameron, Nov 27, 2020
  3. Makoto cameron
    :) no problem, just glad you are sorted too! :)
