BlackBox X32 Stop Job not turning tool off
Discussion in 'OpenBuilds Bug Report' started by Cchomyn, Mar 3, 2024.
  1. Cchomyn
    Cchomyn New
    My X32 will not turn router off when I use stop job. running a job t completion tool shuts off fine, only when i press stop job. I need to use turn tool on and then turn tool off in order to shut router off. Firmware is up to date, GRBL is up to date.
    Update to the latest grblHAL firmware :
    Use http://svn.io-engineering.com:8080/?driver=ESP32&board=BlackBox X32 to build the latest firmware and flash the firmware binary to the X32 using CONTROL, Wizards and Tools > Firmware flashing tool > X32 tab > Machine Style > Custom firmware binary. Select your custom build of the newest firmware
  3. Cchomyn
    Cchomyn New
    Thank you!!! all set.
