Blackbox X32 editing GRBL
Discussion in 'Controller Boards' started by Sword, Jun 16, 2024.
  1. Sword
    Sword New
    Hello,
    Can you edit, compile, and upload to the Blackbox X32 to enable/disable GRBL features, or are you limited to what is provided with grblHAL Web Builder? Just curious, as I'd like to enable single axis homing and possibly homing force set origin. I've read through the "Compiling GRBL" doc, but not sure if that applies to the BBX32.
    Thanks,
    Scott
  3. Sword
    Sword New
    Thanks Peter, I'll check that out and see if I can figure it out. I take it that you can't edit config.h through Web Builder?
    Scott
    Correct, you'd need to setup your own environment for any changes not covered in Web Builder
  6. Sword
    Sword New
    Thanks again Peter :thumbsup:
