Blackbox X32 Door estop not working
Discussion in 'CNC Mills/Routers' started by Osmond, Jan 30, 2023.
Tags:
  1. Osmond
    Osmond New
    Hey all, I have an Estop wired up to the door stop and the light is lit on the blackbox unit and also turns off when I press the button, but in the openbuilds software, it doesnt do anything when I press it. Is there a thing in the settings that I need to turn on so the estop pauses the feed and spindle? I am also planning on installing a dedicated power Estop for the entire system.
    The DOOR input in Grbl is a compile-time option, you can try http://svn.io-engineering.com:8080/?driver=ESP32&board=BlackBox X32 > Safety Door Input tickbox is below the Motor assignments.
    Other options needed to match our default config:
    - set Ganged Y-axis if you have Dual Y motors (Our default config)
    - On the Plugins tab, enable SD Card
    - On the Networking Tab - we enable V3 and Telnet (Remember to install the V3 web interface after flashing as per GitHub - grblHAL/Plugin_WebUI: ESP3D-WEBUI backend for networking capable drivers/boards with SD card support )
  3. Osmond
    Osmond New
    Thank you for the help! After the firmware is flashed, am I supposed to install the index.html.gz file from the web browser?
  4. David the swarfer
    if you want the web interface, yes.
