Blackbox - Relay problem - M3 M5
Discussion in 'Controller Boards' started by snsAlexander, Aug 25, 2020.
  1. snsAlexander
    Hey,
    I've just bought my blackbox and I was testing it yesterday on my Sphinx. I can't seem to activate my spindle ( Makita ) through thee onboard relay.
    I verified the jumper setting on the control board with the documentation. It doesn't react when I try to send the control M3 or M5.
    Hardware problem? If so, how can I test it?
    Send it M3S1000 (if $30=1000 in grbl settings). GRBL needs an S Word because the spindle output can also be used as PWM.
    Also make sure you have a the jumper installed docs:blackbox:jumper-relay [OpenBuilds Documentation]
  3. snsAlexander
    Thx Peter,
    It works fine now. Is there a possibilty to just send M3 instead of M3S1000? M5 works fine without M5S1000.
    Grtz
    You'll have to recompile Grbl and disable the Variable Spindle feature: gnea/grbl but there shouldn't be any need to, all Grbl compatible CAMs and Posts handle the S-Word for you, as does most Grbl GUIs (OpenBuilds CONTROL does add the S Words)
  5. snsAlexander
    Ok Thx I've got my answers and the Sphinx works great
