BlackBox Program Issue
Discussion in 'CNC Mills/Routers' started by JoelW, Oct 10, 2020.
  1. JoelW
    JoelW New
    I recently built up a Workbee 750x1000mm and installed the openbuilds blackbox controller. I have attempted to cut the Openbuild HelloWorld CNC example but the router only plunges into the work piece and I have to abort the operation. This happens with a couple of other examples also. I can use the openbuilds software to home, jog and position the router so at least that much is working. Not sure if the controller has issues or I am doing something stupid. Let me know if you have any ideas.
    Thanks,
    Joel
  2. Alex Chambers
    Maybe stupid question, but you didn't mention it so I'll ask... did you set the workplace coordinates zero?
  3. JoelW
    JoelW New
    Hello Alex,
    Yes I did. The only movement after starting the program is the router going straight down. No X or Y movement. With the Hello World example, the router should move to the middle of the piece before going down. This doesn’t happen, router doesn’t move and just plunges straight down.
    Joel
  4. Alex Chambers
    Again - checking the obvious - is jogging moving in the correct direction - X+ = right, Y+ = back and Z+ = up?
  5. JoelW
    JoelW New
    Yes, jogging works as you stated. I also use the XYZ touch probe and it works correctly in determining position
    #5 JoelW, Oct 11, 2020
  7. JoelW
    JoelW New
    Checked again today and there are no red exclamation lights coming on at any time
    Is your 24v DC PSU maybe plugged into an IoT relay by mistake?
  9. JoelW
    JoelW New
    Not sure what your asking
    1) do you have an IoT relay
    2) if you do, did you by mistake plug in the Power Supply that powers your controller, into the Iot relay instead of the Wall, by mistake
  11. JoelW
    JoelW New
    At first I didn’t understand what the IoT relay had to do with anything.I thought it was nothing but a power strip with a few relay controlled outlets. I plugged the power supply into the wall and everything is now working correctly. So what’s the deal with the IoT?
  12. Peter Van Der Walt
    The socket you had it in, is controller by the signal, to TURN OFF when it gets a signal.
    So when the code turns on the spindle, you turn off the PSU :)
    It is not a power strip after all
    Next to the socket there are written text saying what each socket does
    Normally ON (turns off when it gets a signal)
    Normally OFF (turns ON when it gets a signal)
    Always on (not affected by the signal) (now don't use this as a power strip either, you could exceed the total current rating of the Relay)
  13. JoelW
    JoelW New
    Thanks, I thought normally on meant it was on when the switch was turned on.
    Thanks again for your help.
    Joel
