Blackbox not updating
Discussion in 'General Talk' started by Troy Lee, Apr 27, 2022.
  1. Troy Lee
    Troy Lee New
    I have a blackbox running a Lead 1515. When powering on, the Blackbox will go through all steps and is still usable, but will show "incomplete/failed" when trying to connect to the server to check for an update.
    When connecting to laptop to run a job with Openbuilds CONTROL, a prompt comes up recommending an update via FLASH(ing) the Blackbox.
    IS ANYONE ELSE having this issue?
    I have also started a help ticket with support.
    -Thanks
    Interface or BlackBox? If its the Interface - see Method 2 or 3 of the Firmware Update procedure from docs.openbuilds.com/blackbox to get onto V1.52
