Blackbox - Nema 23 motors stuttering
Discussion in 'Controller Boards' started by Darin, Feb 11, 2020.
  1. Darin
    Darin New
    Hi all, I just recently upgraded my CNC OX to use the Blackbox controller and lead screws instead of belts. I powered it up for the first time last night and tried to jog the motors. All 4 motors just stutter and barely move if they move at all. I adjusted the current up and the stutter just gets louder but the motors will move occasionally. I tested the wiring continuity from the motor plug to the Blackbox plug and all motors are getting good tone. I verified the color pattern on the Blackbox matched the instructions and I verified that my motors use the red/Blue yellow/green pattern for the coils. I've tested my power supply voltage (24V). I've unplugged all motors but one with the same results on all. One oddity that I noted was that the Z axis moves the same direction no matter which job button I use.
    I'm at a loss. Any thoughts?
  2. Darin
    Darin New
    Disregard. Apparently I'm green blue color blind. My motors are reversed on the blue/green axis. :)
    Staff Member Moderator Project Maker Builder Resident Builder
    Glad you got it figured out!
    Don't blame yourself, night time lighting can really mess with how they look! Happens to us all!
    Good luck and have fun
    Darin likes this.
  4. DieterCl
    DieterCl New
    I realy was hoping to Find thé answer here. My motors try to turn but do not move.
    Sorry first time user but realy hoping to der my machine work.
  6. DieterCl
    DieterCl New
    Thank you for thé help. Z and y moters are ok now, but when i did try to test thé x => i got thé message no supported firmware detected => closing port com 3.
  8. DieterCl
    DieterCl New
    Sorry this is probably thé wrong place for this question, but no solution. I did disconnect evrything only thé USB connected => same problem, no problems are thé pc, ... Last option flashing tool answers with "flash failed"
  9. Peter Van Der Walt
    Contact the Partstore at https://openbuildspartstore.com/contact-us-form/ and they will happily assist further
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
