Blackbox Motor Issues
Discussion in 'Controller Boards' started by halifaxson, Feb 2, 2020.
  1. halifaxson
    Hello Team,
    I recently purchased a blackbox (second one for a second machine) and I'm have a strange issue with the X-Axis and Z-Axis.
    X-Axis issue: It will only travel right when pressing X+ and when I press X- it still goes right it will not go the other direction. When I move the whole cable assembly to the either Y1-Axis or Y2-Axis on the blackbox it works fine, so it must be related to the X-Axis port on the blackbox or a software setting that I cannot find.
    Z-Axis issue: When moving the Z-Axis up or down its very jumpy "chatters". When I move the whole cable assembly to either Y1-Axis or Y2-Axis port on the blackbox it works great.
    Configuration:
    - Openbuilds Control Software
    - Openbuilds Blackbox (new)
    - Workbee Belt Drive 1500 form factor (X, Y1, Y2) Lead Screw for Z-Axis.
    I must be over looking something somewhere. Any help would be greatly appreciated.
    Thank You
  2. Gary Caruso
    Hi Halifaxson, Did you try increasing your current Pot on the axis a bit? Sounds like that on the Z but not sure on the X.
    Gary
    Current setting as Gary mentioned, or indeed, wiring. Moving it around to another port as a test may just flex the cable enough that a slightly loose connection somewhere then makes contact, as a chattery motor is almost always 3 of the 4 wires making good contact
    Does it run smoothly or also a bit chattery?
    As a test do disable Hard Limits in Grbl settings (in case a false trigger prevents it moving except "away from the switch" )
  4. halifaxson
    Hi Gary,
    I turned the Z-Axis POT higher just a nip and that smoothed it out tremendously. I then moved it higher by 1 hour just to be sure.
    Thanks for the tip!
  5. halifaxson
    Hi Peter,
    The X-Axis does move smoothly, Hard Limits in Grbl settings are disabled. When I move the whole X-Axis cable assembly to the either Y1-Axis or Y2-Axis or Z-Axis on the blackbox it works fine. Its just when its plugged in to the X-Axis port on the black box.
    The only things that are plugged in to the Blackbox is power, USB to laptop and X-Axis.
    Any Ideas?
    If you plug in a known working motor from another axis, into the X Axis port, does that run?
    Any visual defects on the Muscle board around the X axis connector or driver chip?
  7. halifaxson
    If I plug in another motor, let say from Y1-Axis in to the Blackbox for the X-Axis port it does the same thing, it will only travel forward when pressing X+ and when I press X- it still goes forward it will not go in the away direction. (We're talking Y-Axis motor now in X-Axis Port as a test).
    Not seeing anything odd on the board or solder joints. Its new, only a couple days old, could be a manufacturing flaw.
    Do you see anything wrong on the board? Looks like you need to reach out to http://support.openbuilds.com/support/home too - they'll assist with RMA request
