Blackbox Go To Zero issue
Discussion in 'Controller Boards' started by Mason Dixon, Jan 9, 2021.
  1. Mason Dixon
    Hi, I am having an issue moving my Blackbox/Workbee machine when using Go To Zero.
    The machine moves smoothly when jogging along the y-axis(dual motor config) but when I use the Go To Zero command, it gets going for about an inch or 2 and then one of the motors makes a binding noise and the other motor continues until the gantry is out of square and it stops altogether due to the angle.
    I don't see any motor warning lights when this happens and I've swapped the motor connectors from side to side to no avail. Any ideas on what could be causing this issue?
