BlackBox Fan Speed Adjustment?
Discussion in 'CNC Mills/Routers' started by DustinMan, Jan 2, 2020.
  1. DustinMan
    DustinMan New
    Is it possible to slow the fan down at all on the BlackBox Motion Controller? From the moment I turn mine on, it runs at what seems to be max speed. Generally I wouldn't mind, but it's on the noisy side.
    Its a fixed speed fan. You need all the cooling you can get, stepper drivers heat up from the moment you turn it on.
    That noise is drowned out by the cutting in no time
