Blackbox connect with Radar
Discussion in 'CNC Mills/Routers' started by Kim Martin, Jul 20, 2023.
  1. Kim Martin
    Hi, Im using Acro 55 with Radar module instead of Raser.
    Now, I can control the unit by G-code in yours software. But I want to synchronize my Radar with the path.
    I mean Radar should be turned on or off in particular way.
    So, is there any possible way to synchronize Radar with Blackbox so that Blackbox trigger the Radar?
    Also I want to make a output that reveals the trigger signal (like led or usb port to my laptop...etc) if it posiible.
    Thank you for reading ;)
  4. Kim Martin
    ok I think i can handle mt Radar,
    So what I want to do is triggering my Acro55(blackbox x32) by command line (or batch file)
    Is it possible to make my Acro start job with cmd line? without using RUN JOB button in software tool.
    thanks.
