black box IOT problem
Discussion in 'General Electronics' started by djbart, Aug 7, 2020.
  1. djbart
    djbart New
    setup: c beam xl, meanwell 24v power supply, blackbox, iot switching relay power strip, bosch router openbuilds control software.
    everything has been working well for months. Not router will not turn on. I have checked all connections, wiring diagrams, and the router itself. how can i check blackbox output to IOT power strip or activate power strip without blackbox?
  2. Gary Caruso
    Hi djbart, use a multi-meter and check the voltage of the BB signal, should read 5V DC (at the "toolhead") when the spindle on is commanded.
    You could just plug the router into the always on outlet and manually turn the router on.
    Gary
  3. djbart
    djbart New
    Thanks, Gary i will give that a try.
