Black box and estlcam
Discussion in 'General Talk' started by Charlie Moore, Dec 1, 2019.
  1. Charlie Moore
    Hello,
    Can anyone tell me if estl controller software will work with the black box? All the inputs and whatnot?
  2. Gary Caruso
    Hi Charlie, Yes treat it as an XPro and no problem.
    I ran mine stock GRBL for a while then recently switched to Estlcam firmware/control, mostly as an experiment.
    Gary
  3. Charlie Moore
    Thanks for the reply. When you say treat it as a xpro what do you Mean?
  4. Gary Caruso
    To use Estlcam control you have to "Program Controller", when you do this use the Xpro presets.
    Gary
  5. Charlie Moore
    Thank for the help.
    Regards
    Charlie
  6. Charlie Moore
    Ok one more question.
    I see that it supports 4 axis,but only 3 limit switches. Is there a "y2" limit switch?
  7. Giarc
    You should only need one for Homing. If using as limit switches, for Normally Open you use two in parallel on each end of the axis. If NC, then you can use two in series on each end of the axis. Generally on the Y we have two motors, but they both move the machine the same distance so only one input is needed.
  8. Charlie Moore
  9. Lloyd Downunder
    gyday guys
    I was advised to use Elstcam on my marlin prog. it made every thing at half size, dont know why, got used to this? an adjusted.
    until it fried my Ramps board. magic smoke?? bought the Black box and haven't looked back since.
    as a Cam utility to make g code , works great.
    lloyd
  10. Gary Caruso
    Made everything half size? was this SVG import? need to play with DPI setting to get the scale right.
    Otherwise if using the Estlcam control could be controller settings (distance per rev and steps per rev) may be set incorrectly.
    Gary
    Lloyd Downunder likes this.
  11. Giarc
    I had a similar problem when I first started using it. I selected the wrong microstepping and was making everything twice as big as it was supposed to be.
  12. Peter Van Der Walt
    Thanks for the kind words!
  13. Lloyd Downunder
    thanks Pete
    you guy have woundefull product.
    but, did u read my comment "Stnd alone" worth thinking about, mate
    lloyd
