Black box and SPAM nema23
Discussion in 'Controller Boards' started by Steve Dean1977, Feb 10, 2020.
  1. Steve Dean1977
    After hooking up my lead1010 To the black box no motor moved it they should have. One moved both directions when pushing x+. I can assume red,blue,green yellow out from nema is not same as red,blue, green yellow out. Does anyone have SPAM nema23 motors hooked up to a black box that is willing to share your color code.
  2. Steve Dean1977
    Also just to test I took my z motor off unplugged all motors and put it in y to see if it would act different it didn’t. So I’m assuming it’s a wiring issue
    Check your coil pairs with a multimeter in ohm-meter mode (find the two pairs that give a reading, mark as Coil1, remaining two is Coil2. Wire 1,1,2,2 onto connector
  4. Steve Dean1977
    So 1,1 say red, yellow it doesn’t matter which is in spot one or two it just matters if they are pairs ?
    Get it running first, then if its running in the wrong direction, you can reverse the order (1234 becomes 4321)
