Best Schematic Capture software...
Discussion in 'Other Software' started by Tony LaBelle, Jun 7, 2022.
  1. Tony LaBelle
    Hello,
    I'm about to hop into the electronics portion of my CNC router... Any suggestions on schematic capture software? I'm using Fusion360 for mechanical stuff. AutoCAD offers Eagle schematic capture software but don't know if its any good.
    Thanks!
    Tony.
  2. JustinTime
    JustinTime Veteran
    Eagle is good and it has an option for getting a g-code to route the traces.
  3. Alex Chambers
    Eagle is built into Fusion (a cut down version if you have the personal use license for Fusion)
  4. Tony LaBelle
    Thanks for the response... Alex, you mention 'a cut down version' what do you mean? My goal is to draw up schematic and print them, maybe in the future make PCB's. Would it be better to get another schematic capture program, if so any suggestions?
    JustinTime, do you recommend Eagle or is there another program you prefer?
    Thanks again for the response, Tony.
  5. Alex Chambers
    Only "cut down" in the sense that it is limited to two layers. Double sided PCB's is the limit of my aspirations so I'm fine with that.
  6. Tony LaBelle
    Yup, I agree. I have no intensions to do more than two layers :thumbsup:...Thanks again!
    Tony
  7. JustinTime
    JustinTime Veteran
    Yeah, I use two sides only too. Plenty for me. I used Eagle to make PCBs on my CNC and for having it done in China. Only downside, if it is a downside for you, is that the free version is only good for 100mm x100mm. Didn't bother me so far.
