Benchtop router table
Discussion in 'CNC Projects' started by JayJ, Jun 15, 2021.
  1. JayJ
    JayJ New
    Has anybody come across plans for a benchtop router table that can be cut out on the cnc and then assemble?
  2. Giarc
    Here is one with a sketchup file that you could probably generate a .dxf file for making tool paths. Scott's Router Table
    Are you attaching the router directly to the table, or to a plate set in the table? It would really be a simple project to draw in Fusion 360 that could be customized to your needs.
  3. ljvb
    ljvb Well-Known
    Due to lack of space, I disassembled my router table and moved it to my left table saw wing. I did use the CNC to create the router template for my jessem router lift.
    Can't help you with the cabinet construction, but for the router plate, just use your fav cad/cam software to create the opening, use your plate/lift dimensions, add a 1/32nd of depth to allow for levelling if your plate/lift has the levelling feature.
  4. JayJ
    JayJ New
    Thanks. I have been slowly mocking something up using various ideas... If I finish it I will post it to the projects area
