Axis Calibration vs stepper driver current adjustment
Discussion in 'CNC Mills/Routers' started by Barzalou, Mar 18, 2021.
  1. Barzalou
    Barzalou Well-Known
    Can someone tell me, if you make a change of rotation of one of the four potentiometers on the side of the blackbox, does it mean that you have to calibrate the axis movement distance using the related Wizard routine of the Controller software?
    Negative. Totally unrelated
    Barzalou likes this.
