Avoiding EMI from Light Ring Wires
Discussion in 'General Talk' started by Rink, Dec 29, 2023.
  1. Rink
    Rink Well-Known
    Good afternoon.
    I want to avoid any potential EMI problems.
    Can I run the Light Ring power cable (24v) in the flex tubing and drag chain along with the motor and limit switch cables? Any EMI concerns with that relatively low voltage?
    Thx, rink
    Should be fine, no known reports of that being an issue. Just seperate spindle power cable out if possible (swing arm for example)
  3. Rink
    Rink Well-Known
    Yup, got the swing arm installed, it’s holding the router power cable.
    thanks.
