AUX Blackbox for Communication instead of USB?
Discussion in 'Controller Boards' started by rulebreaker, Jun 21, 2023.
  1. rulebreaker
    Hello,
    can the AUX Port be used to connect the Blackbox with the PC?
    I read all the time how instabil the USB Port is
    from the githubg thing:
    "One of the main problems with streaming to Grbl is the USB port itself. Arduinos and most all microcontrollers use a USB-to-serial converter chip that, at times, behaves strangely and not typically how you'd expect, like USB packet buffering and delays that can wreak havoc to a streaming protocol."
    could i use rs232 plug or rj45 to connect with aux to make a better/more stable connection?
