autostart control
Discussion in 'Control Software' started by Grzegorz123, May 4, 2024.
Tags:
  1. Grzegorz123
    Hi,
    I hate autostart of openbuilds control.
    It is to difficult for programmers to add ONE CHECKBUTTON to enable/disable autostart?
    Any great ideas how to disable this not usable feature?
    Maybe for some part of users is a great option, but not for ALL users.
    Always after login, on center of screen i have open builds control. But I'm NOT ALWAYS using this application.
    Sad.
    Sounds more like you have double startup items. One launching the service (necessary for API, mobile jog server, web UI, and others) and another launching the GUI (not usual so calm down on the poor developers we didn't setup your PC). Cleanup your startup items, or cleanup and reinstall a clean install.
    Otherwise you are always welcome to use a different application altogether lots of Grbl hosts out there.
  3. Grzegorz123
    After last autoupdate openbuilds control always starts. Before update control not starting.
    Exactly so something odd happened. It should still do what it always did.
    Clean your startup items and try again. V1.0.370 to now was a major catchup after almost a year without updates being possible so no surprise sometimes things don't go 100% smooth on some PCs. Its darn diverse out there over tens of thousands PCs. Like a 2 min fix if you have double copies in Startup?
    How to Change Startup Programs in Windows 11, 10, 8 & 7.
