Automatic Tool Change
Discussion in 'General Talk' started by NewbCNC, Oct 7, 2022.
  1. NewbCNC
    NewbCNC New
    Hi All
    Has anybody got experience with installing automatic tool changer to their CNC?
    I've tried contacting the manufacturers but they haven't been very clear, at-least to me in whether this would work or not?
    I wanted to buy the Ratrig Killerbee > Blackbox control and interface
    Then add an automatic tool changer > I came across stepcraft
    I wonder, would the blackbox control and fusion360 allow me to set up tool locations?
    If not, is it possible to get it to work? and how?
    Grbl does not support toolchanges, making it quite difficult to implement.
  3. NewbCNC
    NewbCNC New
    #3 NewbCNC, Oct 7, 2022
  4. Alex Chambers
    What Fusion 360 license do you have? - the personal use license doesn't allow post processing more than one tool, so you wouldn't be able to implement tool changes with that either.
  5. JustinTime
    JustinTime Veteran
    Couldn't that be overcome by combining two files manually with the needed/correct GRBL command joining them?
    In that scenario, the toolchange may as well be manual too (even if you have a toolchanger, using Macros) in between files. Works fine
    Alex Chambers likes this.
