automated jig table
Discussion in 'Other Builds' started by dragonfire81m, Jul 10, 2021.
  1. dragonfire81m
    need some help on the hardware / software department maybe see if the black box would be up to the task .
    im working on an idea to automate a jig table to building square / rectangle frames in different sizes and want a may to change between sizes fast and accrete. using liner rail, acme thread ,and steppers . the y axis will start in the middle of the table and move outward from one another using a single stepper with a forward and reverse acme thread. and the same with the x axis but there will be to separate steppers one per side with the same acme setup as the y axis to make a total of four corners . i have the mechanic side figured out but have no clue on the software any help would
