Ask Grbl CNC questions here.
  1. David the swarfer
    um, no..... a G0 move should move at 10000mm/min according to your $110-$112 settings.
    a G1 move will move at whatever is set by the F word, G0 always uses the maximum rate settings.
    According to this calculator GRBL settings calculator
    10000mm/min at 200steps/mm will exceed a 30khz step rate, which GRBL simply cannot do properly, behavior will be 'odd' at step rates over 30khz. Set your max rates to 8500mm/min and test....
    See the Acceleration calculator on RepRap Calculator - Prusa Printers
    Acceleration and deceleration is a fact of life - you cannot entirely beat physics
    Compensation would be something like 1min20/1min * 1000mm/min. But for actual lasering the burn result is more relevant than the precise speed - do some Calibration burns
  3. sharmstr
    Can someone help me understand why a jog move after a probe doesnt go the programmed 5mm distance? Here's log of what I'm doing.
    Code:
    [09:14:30] [ ? ] <Idle|MPos:-100.001,-100.001,-100.000|FS:0,0>  // Here you can see that the starting point of the probe is Z-100 in mcs
    [09:14:38] [ G21 G17 G91 ] ok
    [09:14:40] [ [ PROBE ] ] Probe Completed.
    [09:14:40] [ G38.2 Z-25 F100 ] [PRB:-100.001,-100.001,-103.526:1]  // Probe triggered at Z-103.526
    [09:14:40] [ G38.2 Z-25 F100 ] ok
    [09:14:40] [ G4 P0.4 ] ok
    [09:14:40] [ $J=G91G21Z5F1000 ] ok  // Now jog up 5mm
    [09:14:40] [ G90 G21 ] ok
    [09:15:22] [ ? ] <Idle|MPos:-100.001,-100.001,-98.619|FS:0,0|WCO:-100.000,-100.000,-100.000>  //Machine coordinates now show Z-98.619.  Expecting -98.526
    There's a difference of .093mm.
    Measured or according to the DRO?
  5. sharmstr
    According to grbl when I get the machine position (MPos) via ?
    FYI - I'm not using G10 to set anything. I'm merely probing down and then moving back up 5mm. See the log above and you'll see that it found the probe at
    -103.526 and then moved up 5mm. I would expect that ? would tell me the machine is now at -98.526 but its saying -98.619.
    Ahh i see it there yes. Nope, got me stumped :)
    Guess attempt 1: after hitting the probe, Grbl decelerated for a little bit before coming to a stop, resulting in minor diff between probe hit point and point it stopped moving? See if probing at F50 vs F100 halves the error too?
  7. sharmstr
    I'll try it it but I'm doing it from my desk. No machine. Just an Arduino with a probe switch attached. I was just curiously really and trying to know more about how this stuff actually works. The difference isnt enough to make a real difference.
    Noted, but the deceleration i am referring to = firmware
    Probe interrupt triggers, maybe (just a wild theory) Grbl's code takes a couple more steps / cpu cycles / polling cycles of some kind to come to actually come rest?
  9. sharmstr
    You're probably on to something there. Lowering the feed rate to 10 dropped the average difference to in the .030mm.
  10. David the swarfer
    yep, acceleration time. that is why you always probe twice, 2nd time much slower.
    with my Z probe I have found that if I always probe at the same speed I can rely on the trigger point to be accurate as calibrated.
    go faster or slower and the trigger point will move a bit, so there is definitely some internal difference between the trigger point and the processing of the trigger point. polled not interrupt? don't fee like delving in the source now.
  11. sharmstr
    Not really worth looking into. Was just making sure it wasnt my code or something else happening in control. I suppose instead of specifying a 5mm move, one could get prb and do a calculation to come up with exactly 5mm. But I'm just using it to move off the probe. It did get me to thinking about how this would effect the efficiency of collecting cloud point data but that's for another day. Thanks, guys!
  12. Jonathon Deadman
    Q3HB64MA drivers
    hey ive picked up an old laser cutter for free but it had an old Leetro controller and as it didnt come with the usb dongle i cant use the software so until im ready to buy a ruida controller i was going to setup GRBL on an uno
    however i am lost as to how and if i can connect the stepper drivers that are in the machine to the uno as they dont have an enable pin and they have pulse and direction + and - pins
    is it posible to drive these with Grbl
    this is the driver i have
    71.0US $ |3phase hybrid stepper motor driver Q3HB64MA|driver stepper motor|motor monitordriver - AliExpress
  13. David the swarfer
    which just means they are enabled all the time..
    but they do have it called 'motor free signal' in the docs
    connect all the - pins together and to signal ground on the Uno (NOT motor power supply ground!)
    connect the + pins to the relevant step and direction pins on the Uno
    This is the same connection scheme as for DQ542 drivers which have been described before in these forums and elsewhere
    3 phase motors, cool, but hard to replace as they are not often stocked
  14. protozach
    protozach New
    Hi, guys, I have a couple issues.
    I'm using GRBL to operate our CNC mill and will list my settings below. Up until now, we've used our mills for a long time with issues I've usually been able to solve with tinkering and minor adjustments.
    My first issue is that I am experiencing random stalls on my X-Axis right away when I initiate an NC file. I can manually tell the X axis to move and it runs great, but within the first 2-3 seconds of a file, the X axis will halt even though GRBL shows it as still moving (no error code and the mill continues to run). This has happened in the past and usually cleaning the machine and restarting it a couple times "fixed" it.
    The next issue is that when it does run, it has lately been naturally stopping and I've been presented with the following windows error:
    "See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.FormatException: Input string was not in a correct format.
    at System.Number.StringToNumber(String str, NumberStyles options, NumberBuffer& number, NumberFormatInfo info, Boolean parseDecimal)
    at System.Number.ParseDecimal(String value, NumberStyles options, NumberFormatInfo numfmt)
    at System.Convert.ToDecimal(String value)
    at GrblPanel.GrblGui.showGrblPositions(String data)
    at GrblPanel.GrblIF.raiseAppSerialDataEvent(String data)
    at GrblPanel.GrblIF.VB$StateMachine_40__client_ComReadData.MoveNext()
    --- End of stack trace from previous location where exception was thrown ---
    at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.8.4420.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    GrblPanel
    Assembly Version: 1.0.9.18
    Win32 Version: 1.0.9.18
    CodeBase: file:///C:/Users/millright/Downloads/GrblPanel-Release-1.0.9.18A/GrblPanel.exe
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.8.4360.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.8.4455.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    System.Windows.Forms
    Win32 Version: 4.8.4400.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.8.4390.0 built by: NET48REL1LAST_C
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Configuration
    Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Win32 Version: 4.8.4084.0 built by: NET48REL1
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    RepeatButton
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Users/millright/Downloads/GrblPanel-Release-1.0.9.18A/RepeatButton.DLL
    Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Data
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
    System.Numerics
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box."
    At first I thought to blame the file itself and had my people double check it and resubmit, however the issue persisted and was replicated on other files that have previously worked. It should be noted that while it stops every time, the error message only appears 50% of the time.
    Here are my GRBL settings: imgur.com[​IMG]
    Any help would be vastly appreciated as a lot of responsibility has fallen onto me to solve this despite never having worked on a CNC mill until just a few months ago. I was just thrown into this and left to my own devices.
    #1364 protozach, Jan 17, 2022
  15. Alex Chambers
  16. David the swarfer
    that error Smells like USB corruption to me. Use a high quality SHORT USB cable and keep it away from power cables (AC and motor power).
    The X stopping is possibly a stepper driver overheat. What drivers are you using?
    Could also be that your rapid speed is right on the edge of stalling and the slightest increase in resistance in the leadscrew makes it stall. Reducing max rate and acceleration will prove this. Keep in mind that the faster a stepper motor turns the less torque it has.
    You have limit switches, therefore EMI is possible, but you should see a related error message. I don't know if GRBLpanel knows how to display that properly though, not updated in 3 years.
    protozach and Peter Van Der Walt like this.
  17. protozach
    protozach New
    Thank you so much. I reduced the max rate accel. by about 30% and this fixed the stalling issue. Crossing my fingers that cleaning the USB ports and switching USB cables solved the other problem.
  18. Gregg Carlson
    I am missing the boat on jogging and working with a new origin.
    Let's say I want to jog 300 in some direction and work from that new offset. I select G54 and even reset it to X/Y/Z=0 with a G10 L2 Px.
    I also issue a G90. My subsequent G1 moves will still reference the machine coordinates, not the G54. I must be making it harder than
    it is - how is something like this done?
    Do I issue a G91? Send only relative moves? Thanks!
  19. Alex Chambers
    No, stick to absolute moves. G10 L20 will set current wcs zero at the current location. G1 (or any movements) can only reference the MACHINE co-ordinate system if there is a G53 at the beginning of the line, so I suspect something is wrong with your setting the wcs zero.
    What was the full command line you entered with G10?
  20. Gregg Carlson
    Thanks Alex,
    It's not working for me, but hear is what I'm trying today:
    $J=G91 G20 F50.0 X100 - issue this 3 or 4 times to get to where I want to start a job
    G90
    'g92 x0 y0 z0 - not sure this works to zero WCS
    G10 P1 L20 X0 Y0 Z0 - seen this both ways, tried both
    G10 P1 L2 X0 Y0 Z0 - they do appear to zero G54 WCS
    G54
    F100
    G1 X100 Y0 - draw a little box, but
    G1 X100 Y100 - backs up to machine 0-0-0
    G1 X0 Y100 - when I'm trying to place the job
    G1 X0 Y0 - to my jogged position
    Something is out of order somewhere or I'm missing something!
  21. Peter Van Der Walt
    It does not. Use G10 L20: See G Codes
    P0 for current WCS or P1-6 for WCS1-6 (G54-59)
    Don't use L2.
  22. Gregg Carlson
    Thanks Peter, if you look, yes, that does seem to zero the G54 WCS.
    But, my subsequent G1 moves revert to the G53 machine coords regardless.
    If you can tell me how to jog to a position, zero the G54, and then work in G54
    I'd appreciate. It is possible I'm going something else wrong, or somehow putting
    it back into G53.
  23. Peter Van Der Walt
    Only "G53 G1" can move in G53. G53 is nonmodal, only applies to lines it starts with. G54-59 is modal (applies since being set until set to something else)
    Jog where you want to be. G10 L20 P0 X0Y0 (assuming you only want to zero XY and keep Z tool length). Done
    Or just use OpenBuilds-CONTROL it has a SETZERO button, Coordinate system indicators, etc (;
    #1373 Peter Van Der Walt, Jan 31, 2022
  24. Alex Chambers
    You can't "put it into G53" unless you put G53 at the beginning of the line - G53 is non-modal - it only applies to the line it is on. You can't accidentally drop into G53 co-ordinates - that's impossible.
    Just to clarify - for your experiments - are you homing the machine first, then jogging to the middle of the bed so you definitely have enough room around your wcs zero position for the G1 moves? I notice your jog moves were only in X - if you were at the MACHINE co-ordinates zero when you started (X right, Y back) and then issued a G1 Y positive move you would be moving beyond limits.
    And a thought occurs to me as I type this - can you confirm that when you jog X+ve moves right and Y+ve moves back?
    PS - send G54 first - then you know everything you are doing is in that wcs.
    #1374 Alex Chambers, Jan 31, 2022
  25. NickEng
    NickEng Well-Known
    Have I lost my mind? Or has page 47 of this thread disappeared?
    I can't find any of the helpful information from @Peter Van Der Walt
    Thanks!
  26. Peter Van Der Walt
    Moved our ongoing discussion to a new thread as it got a little long and on point to your specific implementation. You should have a Notification under the flag icon in top right corner:
  27. protozach
    protozach New
    Does anyone have an idea of what could cause me to need to adjust my Y offset by ~120 out nowhere? Nothing has changed today, but everything I've tried running just runs... low.
  28. Alex Chambers
    Is homing working correctly?
  29. protozach
    protozach New
    Yep, everything goes right home when told to and no other issues. After I shifted the offsets (ended up being about 90-100 difference), you wouldn't be able to tell anything changed.
  30. David the swarfer
    'someone' clicked a 'setzero' button (-:
