Anyone has a post processing script that works with Fusion360??
Discussion in 'CAM' started by thatguypeter, May 10, 2019.
  1. thatguypeter
    Hi,
    I need help getting the Black Box running with Fusion 360. I try all the GRBL post processing cpa in Fusion and some that were mention in this forum (Stroom and Swarfer), but I still can't get the machine to work right.
    What do I need to change in the script to get it to work with the Black Box? I ran the SIM on all the post processing grbl output and it just doesn't run right or run at all.
    Peter
    I am trying to cut out the front hood of my boat and can't get it to work.
    (Made in : Autodesk CAM Post Processor)
    (G Code optimized for OpenBuilds OX CNC 1000 x 750 with GRBL V0.9j controller)
    (Program Name : Stroom)
    (5 Operations :)
    (1 : 2D Pocket1)
    ( Tool : Flat End Mill 3 Flutes, Diam = 6.35mm, Len = 19.049999999999997mm)
    ( Spindle : RPM = 10000, set router dial to 1)
    ( Machining time : 18 min 34 sec)
    (2 : 2D Contour2)
    ( Machining time : 5 min 23 sec)
    (3 : 2D Pocket2)
    ( Machining time : 24 min 24 sec)
    (4 : 2D Contour3)
    ( Machining time : 8 min 17 sec)
    (5 : 2D Contour4)
    ( Spindle : RPM = 20000, set router dial to 3.6)
    ( Machining time : 24 min 21 sec)
    G90 G94
    G17
    G21
    (Operation 1 of 5 : 2D Pocket1)
    G53 G0 Z-10
    G54
    S10000 M3
    G4 P1.0
    X-853.9833 Y674.0642
    Z27.94
    Z15.875
    G1 Z14.716 F1524
    Z12.0015
    X-853.9885 Y674.0581 Z11.9309
    X-854.0037 Y674.0402 Z11.8638
    X-854.0281 Y674.0114 Z11.8036
    X-854.0606 Y673.973 Z11.7533
    X-854.0995 Y673.9271 Z11.7155
    X-854.1429 Y673.8759 Z11.692
    X-854.1886 Y673.822 Z11.684
    X-854.2092 Y673.7978
    G3 X-855.23 Y671.014 I3.2836 J-2.7833 F2000
    G1 X-855.231 Y175.722
    G3 X-854.2031 Y172.9302 I4.305
    G1 X-853.71 Y172.4383
    G3 X-850.926 Y171.417 I2.784 J3.2837
    G1 X-355.595
    G3 X-352.8032 Y172.4449 J4.305
    G1 X-352.3113 Y172.938
    G3 X-351.29 Y175.7219 I-3.2837 J2.784
    G1 X-351.2492 Y675.0393
    X-351.2555 Y675.1026
    X-351.2739 Y675.1635
    X-351.3039 Y675.2196
    X-351.3443 Y675.2687
    X-351.3934 Y675.3091
    X-351.4495 Y675.3391
    X-351.5104 Y675.3575
    X-351.5737 Y675.3638
    X-850.9256 Y675.319
    G3 X-853.7173 Y674.2909 I0.0001 J-4.3045
    G2 X-857.4205 Y673.5479 I-2.5193 J2.9565
    G3 X-860.5131 Y671.3795 I-0.7228 J-2.2586
    X-860.52 Y671.014 I9.5875 J-0.3649
    G1 X-860.521 Y175.722
    G3 X-850.926 Y166.127 I9.595
    G1 X-355.595
    G3 X-346 Y175.722 J9.595
    G1 X-346.005 Y675.8639
    G3 X-346.2565 Y678.1343 I-10.3759 J-0.0001
    X-347.0316 Y680.283 I-8.8958 J-1.9949
    X-347.637 Y680.6537 I-0.6054 J-0.3089
    G1 X-850.9258 Y680.609
    G3 X-860.5131 Y671.3795 I0.0002 J-9.5945
    G2 X-863.4427 Y667.1878 I-4.7206 J0.1797
    G3 X-866.292 Y662.9412 I1.7399 J-4.2466
    G1 X-866.293 Y175.722
    G3 X-850.926 Y160.355 I15.367
    G1 X-355.595
    G3 X-340.228 Y175.722 J15.367
    G1 X-340.233 Y675.864
    G3 X-344.3944 Y686.38 I-15.3671 J0.0003
    G1 X-850.9259 Y686.381
    G3 X-866.292 Y671.014 I0.0009 J-15.367
    G1 Y662.9412
    G3 X-861.4155 Y660.5668 Z11.4649 I3.0162 F1524
    G1 X-850.048 Y669.4732 Z10.9958
    G3 X-854.2092 Y673.7978 Z10.668 I-1.8602 J2.3743
    G1 X-355.595
    X-850.9256 Y675.319
    G1 X-355.595
    G1 X-355.595
    G1 Y662.9412
    G3 X-861.4155 Y660.5668 Z10.4489 I3.0162 F1524
    G1 X-850.048 Y669.4732 Z9.9798
    G3 X-854.2092 Y673.7978 Z9.652 I-1.8602 J2.3743
    G1 X-355.595
    X-850.9256 Y675.319
    G1 X-355.595
    G1 X-355.595
    G1 Y662.9412
    G3 X-861.4155 Y660.5668 Z9.4329 I3.0162 F1524
    G1 X-850.048 Y669.4732 Z8.9638
    G3 X-854.2092 Y673.7978 Z8.636 I-1.8602 J2.3743
    G1 X-355.595
    X-850.9256 Y675.319
    G1 X-355.595
    G1 X-355.595
    G1 Y662.9412
    G3 X-861.4155 Y660.5668 Z8.4169 I3.0162 F1524
    G1 X-850.048 Y669.4732 Z7.9478
    G3 X-854.2092 Y673.7978 Z7.62 I-1.8602 J2.3743
    G1 X-355.595
    X-850.9256 Y675.319
    G1 X-355.595
    G1 X-355.595
    G1 Y662.9412
    G3 X-861.4155 Y660.5668 Z7.4557 I3.0162 F1524
    G1 X-850.048 Y669.4732 Z7.1038
    G3 X-854.2092 Y673.7978 Z6.858 I-1.8602 J2.3743
    G1 X-355.595
    X-850.9256 Y675.319
    G1 X-355.595
    G1 X-355.595
    G1 Y662.9412
    X-866.2845 Y662.8434 Z6.8735 F1524
    X-866.262 Y662.748 Z6.8891
    X-866.2292 Y662.6659 Z6.9342
    X-866.1854 Y662.5891 Z6.9793
    X-866.1433 Y662.5329 Z7.0495
    X-866.0953 Y662.4817 Z7.1198
    X-866.0258 Y662.4243 Z7.2968
    X-866.0001 Y662.4068 Z7.493
    G0 Z27.94
    (Operation 2 of 5 : 2D Contour2)
    G54
    S10000 M3
    X-354.965 Y672.283
    Z27.94
    Z8.35
    G1 Z5.985 F762
    G19 G3 Y672.918 Z5.35 J0.6349
    G1 Y673.553 F1524
    G17 G3 X-355.6 Y674.188 I-0.635
    G1 X-471.494 Y674.1882 F2000
    Z7.9375
    X-490.5439 Y674.1883
    Z5.35 F762
    X-722.332 Y674.1887 F2000
    Z7.9375
    X-741.382 Y674.1888
    Z5.35 F762
    X-854.1 Y674.189 F2000
    X-854.1002 Y559.891
    Z7.9375
    X-854.1003 Y540.841
    Z5.35 F762
    X-854.1007 Y305.895 F2000
    Z7.9375
    X-854.1008 Y286.845
    Z5.35 F762
    X-854.101 Y172.547 F2000
    X-739.793
    Z7.9375
    X-720.743
    Z5.35 F762
    X-485.778 F2000
    Z7.9375
    X-466.728
    Z5.35 F762
    X-352.42 F2000
    X-352.4211 Y286.845
    Z7.9375
    X-352.4214 Y305.895
    Z5.35 F762
    X-352.4236 Y540.8409 F2000
    Z7.9375
    X-352.4239 Y559.891
    Z5.35 F762
    X-352.425 Y674.188 F2000
    X-355.6
    G3 X-356.235 Y673.553 J-0.635 F1524
    G1 Y672.918
    G19 G2 Y672.283 Z5.985 K0.635
    G0 Z17.78
    X-354.965
    Z7.35
    G1 Z4.985 F762
    G3 Y672.918 Z4.35 J0.6349
    G1 Y673.553 F1524
    Z7.9375
    Z4.35 F762
    Z7.9375
    X-741.382 Y674.1888
    Z4.35 F762
    X-854.1002 Y559.891
    Z7.9375
    X-854.1003 Y540.841
    Z4.35 F762
    Z7.9375
    X-854.1008 Y286.845
    Z4.35 F762
    X-739.793
    Z7.9375
    X-720.743
    Z4.35 F762
    X-485.778 F2000
    Z7.9375
    X-466.728
    Z4.35 F762
    X-352.42 F2000
    X-352.4211 Y286.845
    Z7.9375
    X-352.4214 Y305.895
    Z4.35 F762
    Z7.9375
    X-352.4239 Y559.891
    Z4.35 F762
    X-355.6
    G1 Y672.918
    G19 G2 Y672.283 Z4.985 K0.635
    G0 Z17.78
    X-354.965
    Z6.35
    G1 Z3.985 F762
    G3 Y672.918 Z3.35 J0.6349
    G1 Y673.553 F1524
    Z7.9375
    Z3.35 F762
    Z7.9375
    X-741.382 Y674.1888
    Z3.35 F762
    X-854.1002 Y559.891
    Z7.9375
    X-854.1003 Y540.841
    Z3.35 F762
    Z7.9375
    X-854.1008 Y286.845
    Z3.35 F762
    X-739.793
    Z7.9375
    X-720.743
    Z3.35 F762
    X-485.778 F2000
    Z7.9375
    X-466.728
    Z3.35 F762
    X-352.42 F2000
    X-352.4211 Y286.845
    Z7.9375
    X-352.4214 Y305.895
    Z3.35 F762
    Z7.9375
    X-352.4239 Y559.891
    Z3.35 F762
    X-355.6
    G1 Y672.918
    G19 G2 Y672.283 Z3.985 K0.635
    G0 Z17.78
    X-354.965
    Z6.35
    G1 Z5.35 F762
    Z2.985
    G3 Y672.918 Z2.35 J0.6349
    G1 Y673.553 F1524
    Z7.9375
    Z2.35 F762
    Z7.9375
    X-741.382 Y674.1888
    Z2.35 F762
    X-854.1002 Y559.891
    Z7.9375
    X-854.1003 Y540.841
    Z2.35 F762
    Z7.9375
    X-854.1008 Y286.845
    Z2.35 F762
    X-739.793
    Z7.9375
    X-720.743
    Z2.35 F762
    X-485.778 F2000
    Z7.9375
    X-466.728
    Z2.35 F762
    X-352.42 F2000
    X-352.4211 Y286.845
    Z7.9375
    X-352.4214 Y305.895
    Z2.35 F762
    Z7.9375
    X-352.4239 Y559.891
    Z2.35 F762
    X-355.6
    G1 Y672.918
    G19 G2 Y672.283 Z2.985 K0.635
    G0 Z17.78
    X-354.965
    Z6.35
    G1 Z4.35 F762
    Z2.2225
    G3 Y672.918 Z1.5875 J0.6349
    G1 Y673.553 F1524
    Z7.9375
    Z1.5875 F762
    Z7.9375
    X-741.382 Y674.1888
    Z1.5875 F762
    X-854.1002 Y559.891
    Z7.9375
    X-854.1003 Y540.841
    Z1.5875 F762
    Z7.9375
    X-854.1008 Y286.845
    Z1.5875 F762
    X-739.793
    Z7.9375
    X-720.743
    Z1.5875 F762
    X-485.778 F2000
    Z7.9375
    X-466.728
    Z1.5875 F762
    X-352.42 F2000
    X-352.4211 Y286.845
    Z7.9375
    X-352.4214 Y305.895
    Z1.5875 F762
    Z7.9375
    X-352.4239 Y559.891
    Z1.5875 F762
    X-355.6
    G1 Y672.918
    G19 G2 Y672.283 Z2.2225 K0.635
    G0 Z27.94
    (Operation 3 of 5 : 2D Pocket2)
    G54
    S10000 M3
    X-606.1569 Y841.1341
    Z27.94
    Z15.875
    G1 Z14.716 F1524
    Z12.319
    X-606.1491 Y841.1329 Z12.2197
    X-606.1262 Y841.1292 Z12.1228
    X-606.0885 Y841.1233 Z12.0307
    X-606.0371 Y841.1151 Z11.9458
    X-605.9732 Y841.105 Z11.87
    X-605.8983 Y841.0932 Z11.8053
    X-605.8144 Y841.0799 Z11.7532
    X-605.7235 Y841.0655 Z11.7151
    X-605.6278 Y841.0503 Z11.6918
    X-605.5297 Y841.0348 Z11.684
    G17 G3 X-603.2547 Y840.8558 I2.2748 J14.3638
    G1 X-219.4413 Y840.8616 F2000
    G3 X-104.476 Y940.136 I-0.0019 J116.2075
    X-104.4499 Y940.4913 I-2.4072 J0.3553
    G1 X-104.4956 Y1426.0801
    G3 X-135.9637 Y1503.9797 I-112.1528 J0.0009
    X-201.9869 Y1537.2711 I-80.6844 J-77.8987
    X-207.3357 Y1537.8716 I-18.211 J-138.1119
    X-212.7101 Y1538.1644 I-6.5367 J-70.4946
    G1 X-1004.2957 Y1538.2101
    G3 X-1009.1392 Y1537.7646 J-26.5546
    X-1102.0244 Y1426.2394 I20.7216 J-111.7012
    G1 Y934.2069
    G3 X-1100.5686 Y919.0786 I87.0472 J0.7419
    X-1096.6494 Y904.3943 I96.5241 J17.8975
    X-1006.9301 Y840.8496 I89.7203 J31.5668
    G1 X-603.2547 Y840.8558
    G2 X-598.8065 Y837.8904 I0.0001 J-4.8189
    G3 X-594.3583 Y834.925 I4.4481 J1.8535
    G1 X-219.4412 Y834.9307
    G3 X-139.4008 Y864.8302 I-0.002 J122.0882
    X-112.2027 Y898.6673 I-80.0415 J92.1865
    X-103.537 Y918.6638 I-107.2397 J58.3494
    X-100.5764 Y929.162 I-115.9056 J38.3529
    X-99.4508 Y934.4998 I-118.8664 J27.8547
    X-98.9777 Y937.1862 I-119.9927 J22.5171
    G2 X-98.739 Y938.5294 I53.0511 J-8.7331
    G3 X-98.5647 Y939.8824 I-11.0991 J2.1177
    G1 Y1426.08
    G3 X-131.7354 Y1508.139 I-118.0858
    X-168.6777 Y1533.9814 I-84.9125 J-82.058
    X-201.3147 Y1543.1646 I-47.9702 J-107.9005
    X-206.9505 Y1543.7906 I-18.8142 J-143.6635
    X-212.6127 Y1544.0953 I-6.9093 J-75.6499
    G1 X-1004.7178 Y1544.141
    G3 X-1009.8058 Y1543.6731 J-27.8949
    X-1080.1407 Y1502.7417 I22.0292 J-118.7505
    X-1107.9553 Y1426.2434 I91.5806 J-76.6042
    G1 Y934.1564
    G3 X-1106.4153 Y918.0811 I92.939 J0.7922
    X-1102.2616 Y902.4756 I102.3652 J18.8912
    X-1006.9301 Y834.9187 I95.3325 J33.4854
    G1 X-594.3583 Y834.925
    G2 X-589.8719 Y831.9342 I0.0001 J-4.8601
    G3 X-585.3856 Y828.9434 I4.4863 J1.8693
    G1 X-219.4411 Y828.949
    G3 X-92.583 Y939.4768 I-0.0021 J128.0669
    G1 Y1426.08
    G3 X-212.5145 Y1550.077 I-124.0649 J0.001
    G1 X-1007.4935
    G3 X-1113.937 Y1426.2474 I19.0073 J-124.0027
    G1 Y934.1054
    G3 X-1006.93 Y828.937 I107.008 J1.8557
    G1 X-585.3856 Y828.9434
    X-585.3473 Y828.9497
    X-585.313 Y828.9678
    X-585.2862 Y828.9958
    X-585.2696 Y829.031
    X-585.2652 Y829.0695
    X-585.2731 Y829.1075
    X-585.4835 Y829.6535
    X-588.7388 Y841.2385
    X-588.7542 Y841.3596
    X-588.7655 Y841.3981
    X-588.789 Y841.4306
    X-588.822 Y841.4533
    X-588.8607 Y841.4636
    X-588.9007 Y841.4604
    X-588.9372 Y841.444
    X-588.9662 Y841.4163
    X-588.9842 Y841.3804
    X-588.9892 Y841.3407
    X-588.9805 Y841.3015
    X-588.9592 Y841.2675
    X-588.9278 Y841.2426
    X-588.8898 Y841.2297
    X-588.7948 Y841.2146 Z11.6767 F1524
    X-588.7019 Y841.1999 Z11.6548
    X-588.6134 Y841.1859 Z11.619
    X-588.5312 Y841.1729 Z11.57
    X-588.4574 Y841.1612 Z11.5089
    X-588.3935 Y841.1511 Z11.4373
    X-588.3411 Y841.1428 Z11.3566
    X-588.3014 Y841.1365 Z11.2688
    X-588.2753 Y841.1323 Z11.176
    X-588.2492 Y841.1282 Z11.0832
    X-588.2094 Y841.1219 Z10.9954
    X-588.1571 Y841.1136 Z10.9148
    X-588.0932 Y841.1035 Z10.8431
    X-588.0194 Y841.0918 Z10.782
    X-587.9372 Y841.0788 Z10.733
    X-587.8487 Y841.0648 Z10.6972
    X-587.7558 Y841.0501 Z10.6753
    X-587.6608 Y841.035 Z10.668
    G3 X-585.3858 Y840.856 I2.2748 J14.3638
    G1 Y934.2069
    G1 X-585.3858 Y840.856
    G2 X-580.9376 Y837.8906 I0.0001 J-4.8188
    G3 X-576.4893 Y834.9252 I4.4481 J1.8535
    G1 Y1426.08
    G1 Y934.1564
    G1 X-576.4893 Y834.9252
    G2 X-572.0031 Y831.9344 I0.0001 J-4.8601
    G3 X-567.5167 Y828.9437 I4.4863 J1.8694
    G1 Y1426.08
    G1 X-1007.4935
    G1 Y934.1054
    G1 X-567.5167 Y828.9437
    X-567.4784 Y828.95
    X-567.4441 Y828.968
    X-567.4173 Y828.9961
    X-567.4008 Y829.0312
    X-567.3963 Y829.0697
    X-567.4042 Y829.1077
    X-567.6146 Y829.6538
    X-570.8699 Y841.2388
    X-570.8853 Y841.3599
    X-570.8966 Y841.3984
    X-570.9201 Y841.4308
    X-570.9531 Y841.4535
    X-570.9919 Y841.4639
    X-571.0318 Y841.4606
    X-571.0684 Y841.4442
    X-571.0973 Y841.4165
    X-571.1153 Y841.3807
    X-571.1203 Y841.3409
    X-571.1116 Y841.3017
    X-571.0903 Y841.2677
    X-571.0589 Y841.2428
    X-571.0209 Y841.2299
    X-570.9259 Y841.2149 Z10.6607 F1524
    X-570.833 Y841.2002 Z10.6388
    X-570.7445 Y841.1861 Z10.603
    X-570.6623 Y841.1731 Z10.554
    X-570.5885 Y841.1615 Z10.4929
    X-570.5246 Y841.1513 Z10.4213
    X-570.4722 Y841.143 Z10.3406
    X-570.4325 Y841.1368 Z10.2528
    X-570.4064 Y841.1326 Z10.16
    X-570.3803 Y841.1285 Z10.0672
    X-570.3406 Y841.1222 Z9.9794
    X-570.2882 Y841.1139 Z9.8988
    X-570.2243 Y841.1038 Z9.8271
    X-570.1505 Y841.0921 Z9.766
    X-570.0683 Y841.0791 Z9.717
    X-569.9798 Y841.065 Z9.6812
    X-569.8869 Y841.0503 Z9.6593
    X-569.7919 Y841.0353 Z9.652
    G3 X-567.5169 Y840.8563 I2.2748 J14.3638
    G1 Y934.2069
    G1 X-567.5169 Y840.8563
    G2 X-563.0687 Y837.8909 I0.0001 J-4.8189
    G3 X-558.6204 Y834.9255 I4.4481 J1.8535
    G1 Y1426.08
    G1 Y934.1564
    G1 X-558.6204 Y834.9255
    G2 X-554.1342 Y831.9348 I0.0001 J-4.8601
    G3 X-549.6478 Y828.944 I4.4863 J1.8693
    G1 Y1426.08
    G1 X-1007.4935
    G1 Y934.1054
    G1 X-549.6478 Y828.944
    X-549.6097 Y828.9502
    X-549.5754 Y828.9681
    X-549.5486 Y828.996
    X-549.532 Y829.031
    X-549.5273 Y829.0693
    X-549.535 Y829.1072
    X-549.7417 Y829.6552
    X-552.8472 Y841.213
    X-552.8584 Y841.3308
    X-552.8684 Y841.37
    X-552.8909 Y841.4035
    X-552.9235 Y841.4274
    X-552.9623 Y841.4389
    X-553.0026 Y841.4366
    X-553.0399 Y841.4209
    X-553.0696 Y841.3935
    X-553.0883 Y841.3576
    X-553.0938 Y841.3176
    X-553.0855 Y841.278
    X-553.0643 Y841.2436
    X-553.0327 Y841.2184
    X-552.9944 Y841.2053
    X-552.903 Y841.1908 Z9.6452 F1524
    X-552.8136 Y841.1766 Z9.625
    X-552.7279 Y841.1631 Z9.5918
    X-552.648 Y841.1504 Z9.5464
    X-552.5755 Y841.1389 Z9.4896
    X-552.5119 Y841.1289 Z9.4227
    X-552.4587 Y841.1204 Z9.3472
    X-552.4054 Y841.112 Z9.2717
    X-552.3419 Y841.1019 Z9.2048
    X-552.2694 Y841.0904 Z9.148
    X-552.1894 Y841.0778 Z9.1026
    X-552.1039 Y841.0642 Z9.0694
    X-552.0144 Y841.0501 Z9.0492
    X-551.923 Y841.0356 Z9.0424
    G3 X-549.648 Y840.8566 I2.2748 J14.3638
    G1 Y934.2069
    G1 X-549.648 Y840.8566
    G2 X-545.1998 Y837.8912 I0.0001 J-4.8188
    G3 X-540.7515 Y834.9258 I4.4481 J1.8535
    G1 Y1426.08
    G1 Y934.1564
    G1 X-540.7515 Y834.9258
    G2 X-536.2652 Y831.935 I0.0001 J-4.8601
    G3 X-531.7789 Y828.9442 I4.4862 J1.8694
    G1 Y1426.08
    G1 X-1007.4935
    G1 Y934.1054
    G1 X-531.7789 Y828.9442
    X-531.7407 Y828.9504
    X-531.7065 Y828.9684
    X-531.6797 Y828.9963
    X-531.6631 Y829.0312
    X-531.6584 Y829.0696
    X-531.6661 Y829.1075
    X-531.8728 Y829.6554
    X-534.9783 Y841.2133
    X-534.9895 Y841.3311
    X-534.9995 Y841.3703
    X-535.0221 Y841.4038
    X-535.0547 Y841.4277
    X-535.0934 Y841.4392
    X-535.1338 Y841.4369
    X-535.171 Y841.4211
    X-535.2007 Y841.3937
    X-535.2194 Y841.3579
    X-535.2249 Y841.3178
    X-535.2166 Y841.2783
    X-535.1954 Y841.2438
    X-535.1638 Y841.2186
    X-535.1255 Y841.2055
    X-535.0341 Y841.191 Z9.0356 F1524
    X-534.9447 Y841.1769 Z9.0154
    X-534.8591 Y841.1633 Z8.9822
    X-534.7791 Y841.1506 Z8.9368
    X-534.7066 Y841.1392 Z8.88
    X-534.643 Y841.1291 Z8.8131
    X-534.5898 Y841.1207 Z8.7376
    X-534.5365 Y841.1122 Z8.6621
    X-534.473 Y841.1022 Z8.5952
    X-534.4005 Y841.0907 Z8.5384
    X-534.3206 Y841.078 Z8.493
    X-534.235 Y841.0645 Z8.4598
    X-534.1455 Y841.0503 Z8.4396
    X-534.0541 Y841.0358 Z8.4328
    G3 X-531.7791 Y840.8568 I2.2748 J14.3638
    G1 Y934.2069
    G1 X-531.7791 Y840.8568
    G2 X-527.3309 Y837.8915 I0.0001 J-4.8188
    G3 X-522.8826 Y834.9261 I4.4482 J1.8535
    G1 Y1426.08
    G1 Y934.1564
    G1 X-522.8826 Y834.9261
    G2 X-518.3963 Y831.9353 I0.0001 J-4.8602
    G3 X-513.91 Y828.9445 I4.4862 J1.8693
    G1 Y1426.08
    G1 X-1007.4935
    G1 Y934.1054
    G1 X-513.91 Y828.9445
    X-513.8123 Y828.9521 Z8.4483 F1524
    X-513.7169 Y828.9746 Z8.4639
    X-513.6347 Y829.0073 Z8.509
    X-513.5579 Y829.0511 Z8.5541
    X-513.5017 Y829.0932 Z8.6243
    X-513.4505 Y829.1412 Z8.6946
    X-513.3931 Y829.2107 Z8.8716
    X-513.3757 Y829.2365 Z9.0678
    G0 Z27.94
    (Operation 4 of 5 : 2D Contour3)
    G54
    S10000 M3
    X-753.9987 Y843.0378
    Z27.94
    Z9.9248
    G1 Z7.5598 F762
    G19 G2 Y842.4028 Z6.9248 J-0.635
    G1 Y841.7679 F1524
    G17 G3 X-753.3636 Y841.1329 I0.635
    G1 X-425.838 Y841.1379 F2000
    Z9.5123
    X-406.7881 Y841.1381
    Z6.9248 F762
    X-219.4411 Y841.141 F2000
    G3 X-104.775 Y940.3376 I-0.0022 J115.8748
    G1 Y1173.575
    Z9.5123
    Y1192.625
    Z6.9248 F762
    Y1426.08 F2000
    G3 X-212.7229 Y1537.885 I-111.8729 J0.001
    G1 X-398.399
    Z9.5123
    X-417.449
    Z6.9248 F762
    X-795.462 F2000
    Z9.5123
    X-814.512
    Z6.9248 F762
    X-1006.5389 F2000
    G3 X-1101.745 Y1426.2378 I18.0525 J-111.8108
    G1 Y1189.735
    Z9.5123
    Y1170.6851
    Z6.9248 F762
    Y934.2148 F2000
    G3 X-1006.93 Y841.129 I94.816 J1.7463
    G1 X-819.582 Y841.1318
    Z9.5123
    X-800.532 Y841.1321
    Z6.9248 F762
    X-753.3636 Y841.1329 F2000
    G3 X-752.7286 Y841.7679 J0.635 F1524
    G1 Y842.4029
    G19 G3 Y843.0379 Z7.5598 K0.635
    G0 Z17.78
    Z8.9248
    G1 Z6.5598 F762
    G2 Y842.4028 Z5.9248 J-0.635
    G1 Y841.7679 F1524
    Z9.5123
    Z5.9248 F762
    G1 Y1173.575
    Z9.5123
    Y1192.625
    Z5.9248 F762
    Y1426.08 F2000
    G1 X-398.399
    Z9.5123
    X-417.449
    Z5.9248 F762
    X-795.462 F2000
    Z9.5123
    X-814.512
    Z5.9248 F762
    X-1006.5389 F2000
    G1 Y1189.735
    Z9.5123
    Y1170.6851
    Z5.9248 F762
    Y934.2148 F2000
    Z9.5123
    X-800.532 Y841.1321
    Z5.9248 F762
    G1 Y842.4029
    G19 G3 Y843.0379 Z6.5598 K0.635
    G0 Z17.78
    Z7.9248
    G1 Z5.5598 F762
    G2 Y842.4028 Z4.9248 J-0.635
    G1 Y841.7679 F1524
    Z9.5123
    Z4.9248 F762
    G1 Y1173.575
    Z9.5123
    Y1192.625
    Z4.9248 F762
    Y1426.08 F2000
    G1 X-398.399
    Z9.5123
    X-417.449
    Z4.9248 F762
    X-795.462 F2000
    Z9.5123
    X-814.512
    Z4.9248 F762
    X-1006.5389 F2000
    G1 Y1189.735
    Z9.5123
    Y1170.6851
    Z4.9248 F762
    Y934.2148 F2000
    Z9.5123
    X-800.532 Y841.1321
    Z4.9248 F762
    G1 Y842.4029
    G19 G3 Y843.0379 Z5.5598 K0.635
    G0 Z17.78
    Z7.9248
    G1 Z6.9248 F762
    Z4.5598
    G2 Y842.4028 Z3.9248 J-0.635
    G1 Y841.7679 F1524
    Z9.5123
    Z3.9248 F762
    G1 Y1173.575
    Z9.5123
    Y1192.625
    Z3.9248 F762
    Y1426.08 F2000
    G1 X-398.399
    Z9.5123
    X-417.449
    Z3.9248 F762
    X-795.462 F2000
    Z9.5123
    X-814.512
    Z3.9248 F762
    X-1006.5389 F2000
    G1 Y1189.735
    Z9.5123
    Y1170.6851
    Z3.9248 F762
    Y934.2148 F2000
    Z9.5123
    X-800.532 Y841.1321
    Z3.9248 F762
    G1 Y842.4029
    G19 G3 Y843.0379 Z4.5598 K0.635
    G0 Z17.78
    Z7.9248
    G1 Z5.9248 F762
    Z3.7973
    G2 Y842.4028 Z3.1623 J-0.635
    G1 Y841.7679 F1524
    Z9.5123
    Z3.1623 F762
    G1 Y1173.575
    Z9.5123
    Y1192.625
    Z3.1623 F762
    Y1426.08 F2000
    G1 X-398.399
    Z9.5123
    X-417.449
    Z3.1623 F762
    X-795.462 F2000
    Z9.5123
    X-814.512
    Z3.1623 F762
    X-1006.5389 F2000
    G1 Y1189.735
    Z9.5123
    Y1170.6851
    Z3.1623 F762
    Y934.2148 F2000
    Z9.5123
    X-800.532 Y841.1321
    Z3.1623 F762
    G1 Y842.4029
    G19 G3 Y843.0379 Z3.7973 K0.635
    G0 Z27.94
    (Operation 5 of 5 : 2D Contour4)
    G54
    S20000 M3
    X-603.8698 Y1704.25
    Z27.94
    Z15.2
    G1 Z11.835 F300
    G2 Y1703.615 Z11.2 J-0.635
    G1 Y1702.98 F600
    G17 G3 X-603.2348 Y1702.345 I0.635
    G1 X-0.0001 Y1702.355 F2000
    G2 X3.175 Y1699.1801 I0.0001 J-3.1749
    G1 Y0
    G2 X0 Y-3.175 I-3.175
    G1 X-1206.5299 Y-3.193
    G2 X-1209.705 Y-0.018 I-0.0001 J3.175
    G1 Y1699.16
    G2 X-1206.53 Y1702.335 I3.1749
    G1 X-603.2348 Y1702.345
    G3 X-602.5998 Y1702.98 J0.635 F600
    G1 Y1703.615
    G19 G3 X-602.5999 Y1704.25 Z11.835 K0.635
    G0 Z17.78
    X-603.8698
    Z13.7
    G1 Z10.335 F300
    G2 Y1703.615 Z9.7 J-0.635
    G1 Y1702.98 F600
    G1 Y0
    G1 Y1699.16
    G1 Y1703.615
    G19 G3 X-602.5999 Y1704.25 Z10.335 K0.635
    G0 Z17.78
    X-603.8698
    Z12.7
    G1 Z12.2 F300
    Z8.835
    G2 Y1703.615 Z8.2 J-0.635
    G1 Y1702.98 F600
    G1 Y0
    G1 Y1699.16
    G1 Y1703.615
    G19 G3 X-602.5999 Y1704.25 Z8.835 K0.635
    G0 Z17.78
    X-603.8698
    Z12.7
    G1 Z10.7 F300
    Z7.335
    G2 Y1703.615 Z6.7 J-0.635
    G1 Y1702.98 F600
    G1 X-311.156 Y1702.3499 F2000
    Z7.9375
    X-292.106 Y1702.3501
    Z6.7 F300
    G1 Y1425.505
    Z7.9375
    Y1406.455
    Z6.7 F300
    Y859.115 F2000
    Z7.9375
    Y840.065
    Z6.7 F300
    Y292.722 F2000
    Z7.9375
    Y273.672
    Z6.7 F300
    Y0 F2000
    G1 X-292.106 Y-3.1794
    Z7.9375
    X-311.1559 Y-3.1797
    Z6.7 F300
    X-895.369 Y-3.1884 F2000
    Z7.9375
    X-914.4189 Y-3.1887
    Z6.7 F300
    X-1206.5299 Y-3.193 F2000
    G1 Y273.654
    Z7.9375
    Y292.704
    Z6.7 F300
    Y840.047 F2000
    Z7.9375
    Y859.097
    Z6.7 F300
    Y1406.4449 F2000
    Z7.9375
    Y1425.495
    Z6.7 F300
    Y1699.16 F2000
    G1 X-914.4191 Y1702.3398
    Z7.9375
    X-895.369 Y1702.3402
    Z6.7 F300
    X-603.2348 Y1702.345 F2000
    G1 Y1703.615
    G19 G3 X-602.5999 Y1704.25 Z7.335 K0.635
    G0 Z17.78
    X-603.8698
    Z12.7
    G1 Z9.2 F300
    Z5.835
    G2 Y1703.615 Z5.2 J-0.635
    G1 Y1702.98 F600
    Z7.9375
    Z5.2 F300
    G1 Y1425.505
    Z7.9375
    Y1406.455
    Z5.2 F300
    Y859.115 F2000
    Z7.9375
    Y840.065
    Z5.2 F300
    Y292.722 F2000
    Z7.9375
    Y273.672
    Z5.2 F300
    Y0 F2000
    Z7.9375
    X-311.1559 Y-3.1797
    Z5.2 F300
    Z7.9375
    X-914.4189 Y-3.1887
    Z5.2 F300
    G1 Y273.654
    Z7.9375
    Y292.704
    Z5.2 F300
    Y840.047 F2000
    Z7.9375
    Y859.097
    Z5.2 F300
    Y1406.4449 F2000
    Z7.9375
    Y1425.495
    Z5.2 F300
    Y1699.16 F2000
    Z7.9375
    Z5.2 F300
    G1 Y1703.615
    G19 G3 X-602.5999 Y1704.25 Z5.835 K0.635
    G0 Z17.78
    X-603.8698
    Z12.7
    G1 Z7.7 F300
    Z4.335
    G2 Y1703.615 Z3.7 J-0.635
    G1 Y1702.98 F600
    Z7.9375
    Z3.7 F300
    G1 Y1425.505
    Z7.9375
    Y1406.455
    Z3.7 F300
    Y859.115 F2000
    Z7.9375
    Y840.065
    Z3.7 F300
    Y292.722 F2000
    Z7.9375
    Y273.672
    Z3.7 F300
    Y0 F2000
    Z7.9375
    X-311.1559 Y-3.1797
    Z3.7 F300
    Z7.9375
    X-914.4189 Y-3.1887
    Z3.7 F300
    G1 Y273.654
    Z7.9375
    Y292.704
    Z3.7 F300
    Y840.047 F2000
    Z7.9375
    Y859.097
    Z3.7 F300
    Y1406.4449 F2000
    Z7.9375
    Y1425.495
    Z3.7 F300
    Y1699.16 F2000
    Z7.9375
    Z3.7 F300
    G1 Y1703.615
    G19 G3 X-602.5999 Y1704.25 Z4.335 K0.635
    G0 Z17.78
    X-603.8698
    Z12.7
    G1 Z6.2 F300
    Z2.835
    G2 Y1703.615 Z2.2 J-0.635
    G1 Y1702.98 F600
    Z7.9375
    Z2.2 F300
    G1 Y1425.505
    Z7.9375
    Y1406.455
    Z2.2 F300
    Y859.115 F2000
    Z7.9375
    Y840.065
    Z2.2 F300
    Y292.722 F2000
    Z7.9375
    Y273.672
    Z2.2 F300
    Y0 F2000
    Z7.9375
    X-311.1559 Y-3.1797
    Z2.2 F300
    Z7.9375
    X-914.4189 Y-3.1887
    Z2.2 F300
    G1 Y273.654
    Z7.9375
    Y292.704
    Z2.2 F300
    Y840.047 F2000
    Z7.9375
    Y859.097
    Z2.2 F300
    Y1406.4449 F2000
    Z7.9375
    Y1425.495
    Z2.2 F300
    Y1699.16 F2000
    Z7.9375
    Z2.2 F300
    G1 Y1703.615
    G19 G3 X-602.5999 Y1704.25 Z2.835 K0.635
    G0 Z17.78
    X-603.8698
    Z12.7
    G1 Z4.7 F300
    Z2.2225
    G2 Y1703.615 Z1.5875 J-0.635
    G1 Y1702.98 F600
    Z7.9375
    Z1.5875 F300
    G1 Y1425.505
    Z7.9375
    Y1406.455
    Z1.5875 F300
    Y859.115 F2000
    Z7.9375
    Y840.065
    Z1.5875 F300
    Y292.722 F2000
    Z7.9375
    Y273.672
    Z1.5875 F300
    Y0 F2000
    Z7.9375
    X-311.1559 Y-3.1797
    Z1.5875 F300
    Z7.9375
    X-914.4189 Y-3.1887
    Z1.5875 F300
    G1 Y273.654
    Z7.9375
    Y292.704
    Z1.5875 F300
    Y840.047 F2000
    Z7.9375
    Y859.097
    Z1.5875 F300
    Y1406.4449 F2000
    Z7.9375
    Y1425.495
    Z1.5875 F300
    Y1699.16 F2000
    Z7.9375
    Z1.5875 F300
    G1 Y1703.615
    G19 G3 X-602.5999 Y1704.25 Z2.2225 K0.635
    G0 Z27.94
    G53 Z-10
    M5
    G4 P1.0
    G53 X-10 Y-10
    M30
  2. sharmstr
    So, the issue you are having is with simulation only?
    From Peter in another thread
    "Correct, the simulator isnt clever enough for G2/3s sometimes, it just jumps from start-to-end points.
    Will run fine though"
    There are many of us using Fusion360 with the Swarfer post processor and I'm even using those with my BlackBox without issue. Have you tried to actually run the program? Do it without a tool in the spindle if you're worried.
  3. sharmstr
  4. thatguypeter
    I didn't run the SIM program in real time since the SIM wasn't working. I will try it without a bit in it.
  5. sharmstr
  6. thatguypeter
    OK..just tested it..It work great on the actual run! Everything went well! The only issue now is to get it to go to my "set to zero position" for all axis. It doesn't remember the coordinates when I save it in the main panel. This is really critical for repeated cuts and doing the other side of the board. I can't get it to start from the set zero positions. I added the G92 X0 Y0 Z0 but it doesn't work.
    Peter
  7. NthAxisWorkshop
    The tool is ascribed two coordinate positions in CNC, absolute coordinates and relative coordinates (whatcha call machine and work coordinates). When you "set zero", you're setting the starting work coordinates for that job. All gcode is executed relative to that start "work" coordinate (barring an offset). To get to the same spot at the start of every run, you need to click "go to zero" before every job. There is a caveat. If at anytime you've lost steps / position throughout the previous job, it will not return to the exact spot. It will be off. The only way to ensure it gets to the same spot every time is to "home" first, but, when you home your zero is supplanted with "home" zero (absolute). The trick is to jot down your absolute coordinates as a backup, and " gotozero" after you home (mindful of z height), it'll jog to those coordinates. That'll get you to the same spot pretty much every time. Then your coordinates'll be coordinated.
    - Clear as mud? -
    #7 NthAxisWorkshop, May 10, 2019
  8. thatguypeter
    So I have to call the "set zero" work coordinates manually every times before a job right?? OK..I can do that..I am just was used to having it go to my "set zero" running a Marlin CNC..it would do that at the beginning of the job. I do have limits switches on the machine..I did test it with a "Home" call out and then a "Go to Zero" afterward and it work every time manually.
    Does the Black Box software remember or store the "Set Zero" after it off? I can't get it to go to the same location after every power off and on..I have to reset it manually with the coordinates written on my spoiler board..
    Peter
  9. NthAxisWorkshop
    Well, you only set zero once for a particular work piece. As for saving work zero after a power cycle...I'm pretty sure it does. When you click "setzero" in Openbuilds Control (G10 P1 L20 X0 Y0 Z0), it stores your absolute coordinates in P1 (G54). That will stay in the eeprom until it's overwritten or reset. Come to think about it, you also have 5 more work "presets" (called offsets). You home first, jog to where you want a preset to be and then you would store them with the same gcode line, just substitute the "P1" part with "P2" or "P3" and so on. When you need them, you call them at the start of your program with G54, G55, G56 and so on (respectively).
  10. sharmstr
    "So I have to call the "set zero" work coordinates manually every times before a job right?? " No you dont have to. You only want to do this if your work coordinates have change since the last job.
    "Does the Black Box software remember or store the "Set Zero" after it off?" Yes
    "I can't get it to go to the same location after every power off and on" Are you homing first?
    Be aware that when you rehome, the dros will show how far you are away from where you set your work coordinates. It will not show you 0,0,0. I only mention this because I see people on here get confused by that. This doesnt sound like your issue, but thought I'd throw it out there just in case.
  11. Alex Chambers
    Note - please "upload file" rather than pasting the text - it causes havoc with my phone when you do that.:D
    Glad to see you are getting sorted.
    Alex. :):)
  12. thatguypeter
    Thanks for the all the help guys. I will start the real first cut on this huge machine today. I am hoping to get the boat done in 1-2 months. I will post picture for those who might want to see it.
    Peter
    NthAxisWorkshop and sharmstr like this.
  13. thatguypeter
    I ran the real program this morning and it not cutting right. It's cutting in the air above the stock material. I ran the SIM in Fusion and it set right and cutting into the material as programmed. I did an auto home and then set my zero position to where it should start from, so everything is set at zero and the program run and goes to the first cutting position, but its raised the Z to 27MM up and cuts in the air...
    What am I doing wrong?
    Peter
  14. sharmstr
    Your code is telling it to do that. Double check that your setup in fusion and make sure your work origin matches where you set your Z0. If I were to guess, you have Z0 in fusion set to bottom of stock and your Z0 on the machine set to top of stock. Cant say for sure without more info. If you want to give me access to your fusion file, I'll be happy to look at it for you. Send me a DM and I'll give you my info.
    NthAxisWorkshop likes this.
  15. thatguypeter
    Its still cutting above the material. I check the Z0 and its set at the lower left corner of the stock top. How do I send to the front hood fusion section to look at?
  16. Alex Chambers
    @sharmstr was suggesting that you start a conversation with her so that she could tell you how to share your Fusion folder with her - as its stored in the cloud you can give her permission to access your files. Alternatively you could EXPORT your file from fusion as an archive file - *.f3d (save to your computer) and then upload it to a post here.
  17. thatguypeter
    OK..here is the .f3d file for the front hood of the boat. I didn't had this issue with the Lowrider 2 CNC. I cut most of the main parts on it out already and had no problem with a Marlin program setup, but the machine was very problematic and not very rigid,..I had to constantly monitor it and fix it. This machine is more rigid and accurate....super fast too..when it does touch the material and start to cut into it...it has no problem doing it..well it routed out the outline and I got a template of what needs to be cut out. I can use a hand router to finish the rest of the hood.
    I just need to final out what I am doing wrong with the GRBL setup and learn from it..also if I need to make changes in Fusion 360 for machining with GRBL or not..
    Any help would be much appreciated!
    Peter
  18. sharmstr
    It seems to post fine for me. I even tried 5 other post processors and they all start at Z10.16
    Code:
    X-853.98334 Y674.06421
    Z10.16
    X-853.98334 Y674.06421 Z10.16
    X-853.98334 Y674.06421 Z3.175
    G1 X-853.98334 Y674.06421 Z2.016 F1524
    X-853.98334 Y674.06421 Z-0.6985
    X-853.99896 Y674.04578 Z-0.81999
    X-854.04345 Y673.99328 Z-0.923
    X-854.11004 Y673.91471 Z-0.99182
    X-854.1886 Y673.82202 Z-1.016
    X-854.20917 Y673.79779 Z-1.016
    Even if I set the origin to the bottom of the stock, it starts at Z22.86 so that's not it.
    I dont know if I'm gong to be able to explain why It posts fine for me and not for you. So, I started digging into the design. I was able to get similar Z values if I rolled your design back a few extrusions. Is it possible you posted a few times and loaded a previous gcode file and not the latest one? Just a guess.
  19. thatguypeter
    Can you tell what post processing script you used. I used the Stroom one and my Z start is higher then your... I think it was at 15.10..on the Fusion Sim it run perfectly, once I post it and run it in GRBL it's running in the air..
    Peter
  20. sharmstr
    The swarfer version of the stroom post: swarfer/GRBL-Post-Processor which by the looks of it, is the one you used
    Can you double click on your setup and resave, regenerate your tool paths, then repost? I remember a long time ago having a similar issue and Fusion hadnt updated my setup after I made a design change.
    thatguypeter and Alex Chambers like this.
  21. thatguypeter
    It's finally running right! I had setup the "Front Hood" as a brand new process. Its only work after I created new tool paths for all the cuts and selected the material as the "Model Body", then it work perfectly.
    Thank you everyone for the support, I thinking about changing the X axis design to the open build C Beam double carriage and spindle setup...there to much flex going on with my current setup on the Z axis. Its cutting 2MM multiple passes without issue, however when I sent it to 3MM depth it's causing to much skips on the belt. Feed rate at 2000mm/min.
    Peter
  22. sharmstr
    Excellent. Sorry it took me forever to remember that I had that weird no update issue a few years ago. LOL.
  23. David the swarfer
    Marlin does not work at all like GRBL does. Forget that and learn the GRBL way'
    Yes indeed GRBL (the software on the blackbox) will remember your work offsets through power outs. I have never had a problem restarting a job after a power failure, something that happens often here in Africa.
  24. Peter Van Der Walt
    Keep in mind between each job, the material will just be in a slightly different spot or a slightly different height. ZERO = Where's the Material. HOME = where's the machine. Two different things :)
