Any way to use X-Pendant?
Discussion in 'Interfaces' started by Will Dumas, Nov 10, 2020.
  1. Will Dumas
    I still have an X-Pendant (X-Pendant – MechanicalGoose) from when I had my X carve, is there any way to use this with the OpenBuilds Control software? I've tried key mapping and it didn't work, every button I pushed on the X-Pendant came up as "enter" in the key mapping tab on the OpenBuilds software.
  2. sharmstr
    Never used the X-Pendant so cant say for sure. What happens when you press those same buttons in notepad? Do you still get "enter"? If so, you'll have to program the x-pendant.
  3. Will Dumas
    I will have to try this later, didn't think about that. Thanks.
  4. Will Dumas
    When I push a button the pendant with Notepad it actually puts GCode into notepad.
    I'm guessing I'll have to figure out how to reprogram this thing.
  5. sharmstr
    Yes you need to reprogram it. I looked at their website the other day. Seems pretty straight forward.
  6. Will Dumas
    For most people you're probably correct, for me.......that's another story o_O
    Giarc and sharmstr like this.
  7. Mark Carew
    All I can say is hold on just a little longer and pretty soon all of your wildest dreams may come true ;)
  8. Will Dumas
    Glad to hear, as I got into the programming and it's extremely complicated, definitely nothing I can manipulate to suit my needs.
