Any way to get the probe command to show how much the Z axis changed when the Z is updated?
Discussion in 'Control Software' started by Dan Biskup Home, Jun 11, 2022.
  1. Dan Biskup Home
    Often when I probe I'd like to know how much the Z axis changed. Good way to tell just how flat a surface is. Can that info be added to the probe confirmation screen?
    Thanks for the suggestion
  3. David the swarfer
    in the meantime you can do it yourself.
    in the Serial Console give $# which shows data like
    Code:
    [09:42:50] [ $# ] [G54:-60.000,-50.000,-20.000]
    [09:42:50] [ $# ] [G55:123.000,321.000,-3.140]
    [09:42:50] [ $# ] [G56:0.000,0.000,0.000]
    [09:42:50] [ $# ] [G57:0.000,0.000,0.000]
    [09:42:50] [ $# ] [G58:0.000,0.000,0.000]
    [09:42:50] [ $# ] [G59:0.000,0.000,0.000]
    [09:42:50] [ $# ] [G28:0.000,0.000,0.000]
    [09:42:50] [ $# ] [G30:-100.000,-97.000,3.000]
    [09:42:50] [ $# ] [G92:0.000,0.000,0.000]
    [09:42:50] [ $# ] [TLO:0.000]
    showing that my Z offset for G54 is -20.
    compare that to the offset after your probe and will know how much it changed.
