Advice on CO2 Laser Build
Discussion in 'Laser Cutters' started by 2x3 CNC, May 21, 2019.
  1. dandealer
    dandealer New
    Sorry i had been not clearer in my drawing. Pot is grounded on ground pin. so I have pot wired this way: "GND,IN,5v"
    I had been testing with several lightburn configs and with pot set to max I have 10mA, it stays in 10mA when rotating pot conterclockwise till I reach half of pot range, then it keeps going down when i rotate por til it reaches 0mA. its like for some reason its capped to 10mA max aprox. But if i use test button it can fire to whatever I set the pot ( i had been carefull to not pas 20mA mark)
    Confirm that gcode from Lightburn, when you set 100%, has M3S1000s in the file? (and not like M3S255)
  3. dandealer
    dandealer New
    Ok, I didnt know what was the problem but now it works.
    I found that lowering velocity setting to 300 mm/min laser started to fire at desired power.
    I deleted the machine setup, created a new one with same values and now it fires as intended at any set velocity.
    Thanks for your help.
  4. sitoru
    sitoru New
    this post is old, but it was exactly what i was missing in my configuration, i had not been getting the correct milliamps until I connected the 5v to in. Now my laser is actually burning and cutting like its supposed to.
    I recently added an amMeter to my laser and to my surprise I was only getting around 10ma even at full power. I had it like that for almost 2 years.
