Adding a Laser to Lead 1010?
Discussion in 'CNC Mills/Routers' started by gregers05, Feb 26, 2019.
  1. gregers05
    gregers05 Well-Known
    Has anybody had success adding a laser to a Lead or workbee?
    I am in the process of purchasing a CNC router and am looking at the Shapeoko 3 XXL or the Leads 1010. Leaning towards the Leads system, however an advantage the Shapeoko has is that J-Tech has a kit to add a laser engraver. This is something I would likely add on in the future, so I would like to have the option to add it if I decide to. I did a search here and didn't see much.
  2. MaryD
    MaryD OpenBuilds Team
    You are in luck! J-Tech kit for standard OpenBuilds spindle mount
    Also, you'll be able to take complete advantage of all the flexibility offered in the brand new BlackBox controller (Plug and Play - no crimping, no soldering with our Xtension wiring system) + our free software that has settings built right in making setup a breeze! BlackBox info
    RCNunya, GrayUK and Rick 2.0 like this.
  3. ljvb
    ljvb Well-Known
    I brought the laser topic up in the other thread for the lead build. You note the Blackbox will work, I picked up an unused OB full setup on Ebay from some guy in Florida, it comes with the XPro V4. Will the XPro V4 support running the laser as well?
  4. MaryD
    ljvb likes this.
  5. Giarc
    Yes it will.
    Yes it will
    *Oops. I guess it was already answered before my phone refreshed
  6. Rick 2.0
    She beat you by an hour and a half. How slow is your phone???? :eek:
  7. ljvb
    ljvb Well-Known
    Must be an iPhone :)
  8. Giarc
    I was in a class I never knew I was going to be taking. It involved a whole lot of math. My brain was mush. I opened the page on my phone and it took an hour and a half to get to the break by the time I read it and replied. I have a feeling the unexpected physics lessons today will cause that PTSD dream (from college) where I was registered for a class I did not know about and it is too late to drop it so I am going to fail. You now the one...right? Or, am I the only one that still occasionally has that dream 30 years later?
  9. gregers05
    @MaryD does this replace the Pro V4, or do you still need to get that when I order the machine? I assume if I got this, I wouldn't need to get the pro v4 also, but just wanted to check.
    Also, a little off topic, but how often do things get restocked in the parts store? I see the wiring kit is out of stock now.
  10. ljvb
    ljvb Well-Known
    It's one of the other.
  11. BruceD
    BruceD New
    @MaryD if I purchase this laser mount, is the compatable with a dustboot?
  12. MaryD
    We have not used the mount here. Perhaps someone with experience can chime in....
  13. jamin35008
    jamin35008 Well-Known
    1. Wondering if the Lightburn software is the way to go for running the Jtech 2.8 laser on the lead 1010?
    2. I think I'm right in saying that the blackbox controller will work with the Jtech laser?
  14. seanhawk
    seanhawk New
    Just got my 1010 built and working on installing the 4.2 laser. Any input from someone already running the set up? Any information or insight would be appreciated.
    Thanks!
  15. Steve Scott
    Hi Sean, I'm just wondering how you went with this ?
