Added a macro incorrectly, now I can't delete it
Discussion in 'OpenBuilds Forum Help' started by Hmatyas, Jun 21, 2024.
  1. Hmatyas
    Hmatyas New
    I added the macro OpenBuilds UI for use on tablets. I did something wrong. Now even if I remove OpenBuild from Add or Remove programs, and I delete the folder OpenBuilds and all the other folders and files. When I reinstall OpenBuild I get the screen which is attached. Lucky for me, this is not the computer that I use OpenBuild with my CNC. However, I like to install things to check to see how it works. In this case I installed it incorrectly and need to fix.
    Thank you.
    Harvey
    #1 Hmatyas, Jun 21, 2024
    Ctrl+Shift+i to open Devtools
    Go to the Application tab
    Go to Storage > Localstorage > localhost
    Scroll down to macroButtons
    Right Click on macroButtons > Delete
    Lastly hit F5 to refresh the page and you're back to a clean no-macro CONTROL
    #2 Peter Van Der Walt, Jun 22, 2024
  3. Hmatyas
    Hmatyas New
    Peter
    Thank you. It worked! When I first read your email, I could not do it because I missed the i in the Ctrl+Shift+i.
    But I looked at your email closer, I saw my mistake. Again, Thank you.
    Harvey
