ACRO system - DXF files for mounting plates?
Discussion in 'Laser Cutters' started by Lemmy, Aug 27, 2020.
Tags:
  1. Lemmy
    Lemmy New
    Hi all,
    I just put together an ACRO system, for drawing in the meantime but possibly laser cutting at some point in the future. I'd like to design my own 3D printed mount for my pen holder, and wondered if there are DXF files I can access for the acrylic mounting plates on the X-axis of the ACRO system? So that I can get my dimensions correct.
    Thanks,
    L
  2. Lemmy
    Lemmy New
    OK, I found a link to a DXF for the main plate with the long slots in the other ACRO thread. The main DXF posted on the site isn't compatible with my software packages.
  3. Giarc
    You can download the model from here: OpenBuilds | 3D Warehouse and open it in sketchup. Then take the measurements, or save the plate as an .stl and open it in your preferred CAD.
  4. Marco Mello
    Can you share the link? I don't find the files in anyplace.
    See the link provided
    Click the Products tab, use the Filter block to search for "acro"
  6. Rick 2.0
    If you're using an older version of Sketchup try OpenBuilds ACRO System
