ACRO Laser.
Discussion in 'Laser Cutters' started by Richard Gallatin, Aug 3, 2021.
  1. Richard Gallatin
    I have the ACRO system with the BlackBox. I am using the NEMA 17 steppers 1.9 with 14 tooth pulleys. I would like to upgrade and was wondering if I can us a .9 stepper with a 16 tooth pulleys and belts.
    Yes, just remember to set new steps per mm values in Grbl Settings and make sure its 3v/1.3A or higher motors. BlackBox is 1.2-1.3A minimum
  3. Richard Gallatin
  4. Richard Gallatin
    Little more help maybe needed. I installed my .9 Steppers. These motors seems to be running warmer than the 1.9's My temps are 118 degrees to 125 degrees. Just wondering if this is to hot. I am using the blackbox. I have turned the voltage down. Is there anything else I should be looking at.
    Did you spec them correctly? If they are low current motors, BlackBox has a 1.2-1.3A minimum (ideal for 1.7A motors, as you don't want to run motors at their max rating. You want to run it below) and up from there. Check your motor datasheets - if they are too low current they would not be a good match for a BlackBox
    C or F?
    Motors do run warm, but shouldnt be hot enough to burn your hand, melt insulation, warp the Acro plates, etc
    #5 Peter Van Der Walt, Aug 18, 2021
  6. Richard Gallatin
    Do you have any recommendations on where to get stepper motors i found a place on Amazon but not sure on amps. It says a 2a but not positive.
    We have ours only in 1.8 deg.
    Amazon specs are hard to find for sure. The theoretical resolution doubling of 0.9deg motors are very impractical though - half the speed, and the frame is the bigger contributor to accuracy error anyway.
    Our standard Acro+BlackBox config has 1/8deg motors, with GT2 16T pulleys and 1/8th microstepping: Lets calculate the resolution
    200 steps per rotation * 8 microsteps = 1600 microsteps per rotation
    16T * 2mm pitch GT2 = 32mm per rotation
    32mm / 1600 microsteps = 0.02mm already - you cannot measure that distance in the results of any laser engraving
    With 0.9deg motors, that doubles to 0.01mm (but half the maximum feedrate) The difference is 100% yes, but.... the difference between 0.01mm and 0.02mm is ONLY 0.01mm - is it worth the cost, effort, and loss of speed?
    Improving the mechanicals on the other hand: How to calculate V-Slot® deflection comes into play, and the acrylic plates which can flex quite a bit, lack of Eccentric spacers to perfectly adjust the wheels, etc makes the Acro a budget machine, and can benefit from upgrading on the mechanical front much more than in the drive system
