Acro 20x20 rough/load Y axis movement
Discussion in 'Other Builds' started by Shelby Teknologies, Jan 10, 2019.
  1. Shelby Teknologies
    The X axis with the xPro v4 is really quiet and smooth but the Y axis is loud. The belts seem fine but just wondering if anyone else has run in to this?
  2. GrayUK
    Any chance of a video?
    Is it mechanically loud or electrical loud, if you see what I mean?
  3. Shelby Teknologies
    mechanically. I took the X axis off and both the Y axis seem to be really not right so I will see what I can figure out before doing a video as the electrical is all removed again.
  4. GrayUK
    Is your Y driven by 2 motors or 1?
    If 2 they could be going out of sync. Are they fed from one shared port, or 2 independent ports?
  5. Shelby Teknologies
    Two, I think I figured it out. It appears the acro rails loosened up so the X was perfectly smooth but the Y both had too much play. I'm working to resolve this. When it would go back and forth it had too much slop so it bangs because it isnt locked to the rail but I'm still not sure why both the Y axis rails slipped.
