ACRO 1515: 1500x2000mm
Discussion in 'DrawBot' started by Dr. Woohoo!, Sep 5, 2021.
  1. Dr. Woohoo!
    Hello!
    With the help and advice from openBuilds, I have received my order (#142153), reviewed the parts list, and began to build it. As the title mentions, its size is 1500x2000mm and my intention is to make it a drawing bot by leveraging the drawing mechanism from my Axidraw v3/a3.
    I received the following V-Slots:
    1. 1 x V-Slot 20x40 2000mm
    2. 2 x V-Slot 20x20 2000mm
    3. 2 x V-Slot 20x20 1500mm
    Based on an earlier email conversation w/openBuild, I was expecting 1 x V-Slot 20x40 2000mm, 2 x V-Slot 20x20 2000mm, and 2 x V-Slot 20x40 1500mm. This brings up two questions (please see attached diagram for clarity):
    1. Should the V-Slot 20x20 1500mm be 20x40 because the Y-axis and Y2 motors will be attached to them?
    2. Should the X-axis motor be attached to the longest rail (2000mm) similar to the ACRO 510 (20" x 40") vs the ACRO 1510 (60" x 40")?
    For fun, I have added a photo of the Axidraw drawing mechanism attached to the front X-Axis plate.
    Thanks!
    Drew
    #1 Dr. Woohoo!, Sep 5, 2021
    The store asked me to relay to you that they will happily rectify the packing mistake and send out the correct parts to you today! In future, for packing/order/store related queries, please contact the Store team directly via https://support.openbuilds.com > Submit New Ticket
    Thank you for your patience.
  3. Dr. Woohoo!
    Good to know x 2, thanks Peter.
