accuracy issue ooznest ox (what am i doing wrong)
Discussion in 'CNC Mills/Routers' started by tore micaelsen, Mar 7, 2016.
  1. Jimmybuckets
    Jimmybuckets Well-Known
    Are you using Mach3 or GRBL?
  2. Stanley Kitowski
    GRBL for both the old and updated CNC frame. I did use the old DRV8825 for the old CNC. This setup made perfect circles. The updated CNC used GRBl with the TB6600 drivers.
    I will test my drivers, but I think you might be right about it being mechanical.
    The reason it might be mechanical is that the old CNC used a solid 40x40 extrusion for the gantry rails instead of two 80x20 extrusions.
  3. Jimmybuckets
    Check how your cuts look club vs conventional
  4. Stanley Kitowski
    Hey Jimmy!
    Looks like I found out what's causing the misalignment!
    Not the software, not the steppers, not the direction of cut, not the drivers..
    It was the eccentric v-wheels! What's weird was that I needed to loosen them NOT tighten, haha.
    After I loosened them ALL (including the z-axis) to the point of the wheels being able to spin a bit, I was able to get super concentric circles! :)
    Thanks you guys for your help!
    Ga Costra and GrayUK like this.
  5. Jimmybuckets
    Happy cutting. Glad to help
    Stanley Kitowski likes this.
  6. GrayUK
    Got to admit, I wouldn't have looked there!
    (Make mental note to myself) :rolleyes:
  7. whoisthedaddy
    This thread literally stopped me tearing my hair out! I had exactly the same problems and had tried everything - everything except loosening the concentric nuts on the x axis!! As soon as I did this it worked... thankyou everyone for contributing!
    GrayUK likes this.
  8. Ga Costra
    Ga Costra New
    Thanks Stanley!! You save me! I had this problem and was losing hope. Now, its solved. Thanks for sharing!
