AC Switch PN used in PowerCase Kit
Discussion in 'General Electronics' started by Sean McVeigh, Jan 3, 2020.
  1. Sean McVeigh
    I'm designing a 3d printed version of the PowerCase Kit for another PSU (RS-100/RD-88/RID88), which has different dimensions than the PSU the PowerCase Kit was designed for (LRS-300). I was hoping someone could link the combined switch & plug part used in the kit so I can use it in my project?
    [Edit] Also, the PN for the header that mates with the Male Power Supply Connector?
    Thanks.
    #1 Sean McVeigh, Jan 3, 2020
    I don't have the part numbers readily available, but Digikey is awesome at finding any connector your heart desires
    The output pins are Phoenix 5.08mm Pluggable Terminals. Use the filters on digikey to find the exact one you need (maybe panel mount instead of pcb for example)
    Mains plug is C14/C15 IEC with an integrated switch, again, filter Digikey :)
    Sean McVeigh likes this.
