A bunch of newbie questions, CNCjs & GRBL & xPro v4
Discussion in 'General Talk' started by Apeli, Nov 18, 2019.
Tags:
  1. Apeli
    Apeli New
    Hi all,
    just cut my first chips on my custom OX-build. A circle came out as a circle, great success!
    Still, a few questions regarding the software/controller combo. I'm running CNCjs on my Mac and it's connected to a xPro v4 -controller board which has GRBL 1.1 installed by default.
    The first problem is that a lot of the CNCjs buttons trigger G-code commands that GRBL has no idea about, like G28.2, G28.3 for homing & zeroing. Apparently those are TinyG-specific commands? And what the heck are the values in the GRBL widget (https://cloud.githubusercontent.com...42/5912660e-b4fb-11e6-8ff8-60b2602f5d79.png)? Is there a way to install/make CNCjs with GRBL-supported commands?
    The second problem was that I can't write any GRBL commands (like $102=400) to the Console widget on the CNCjs, only G-code. Trying to type the dollar symbol just gives error messages of faulty commands. The only way I've managed to send GRBL commands has been to create a custom buttons with the GRBL commands on the Axes-widget. Works, but slightly cumbersome.
  3. Apeli
    Apeli New
    Thanks, had not bumped into that! Doesn't look as slick as CNCjs but will definitely try it out tonight.
    Its less "almost working bells and whistles" in favour of "easy to understand for newbies"
    Apeli and sharmstr like this.
  5. ssbxfire
    ssbxfire New
    you can also look into using bCNC though I have found I would rather not get my Mac full of dust in the shop so using a Raspberry Pi 4, a 3 will work also.
  6. Apeli
    Apeli New
    Very pleased with the OB Control! Does exactly the things I want. Also the OB Cam -webapp was a great find. Thanks!!
    Glad you like it! :)
    Cannot wait to see all the cool Projects you are going to make with it!
