60w CO2 Laser BlackBox wire up
Discussion in 'Laser Cutters' started by SirCrem, Aug 7, 2019.
  1. SirCrem
    SirCrem New
    Hey Guys im just finishing up setting up a co2 laser and blackbox controller and have a quick question on the wiring.
    On the blackbox I am using the ground pin (black wire) and pwm pin (red wire) in the toolhead pin section
    On my power supply for the co2 laser ground pin goes to the ground pin from the blackbox and then also on the psu I have TH TL and IN ( which is a pwm signal input 0 - 5v )
    So my question here is do i wire the pwm from the blackbow to TH or IN
    Thanks!
      File size:
      199.7 KB
      90
    TH = PWM
    WP = GND
    IN = 5V (or 5v via a potentiometer = sets the current scale (set potentiometer to 50% limits power to 30w. So 0-100% on PWM will be 0-30w) (set potentiometer to 100% limits power to 60w. So 0-100% on PWM will be 0-60w) - adding this gives you some "on the fly" tuning of power, quite useful
    PWM x (IN/5) = Power output :)
    SirCrem likes this.
  3. SirCrem
    SirCrem New
    You are the man with the plan thank you Peter!
  4. SirCrem
    SirCrem New
    So im going to wire the PWM (from blackbox ) to TH (LPSU) then ground (from blackbox) to ground (LPSU) which I also bridged to wp
    I am also going to get a potentiometer so i can have that on the fly tuning. If i set the laser power through the blackbox and then touch the potentiometer will this interfere with the blackbox, or will it plainly just add and subtract on top of the value i set in the controller
    Correct
    It will not interfere, it will supplement (Grbl sends PWM, potentiometer just modifies the scale - so if you start a photo engraving and see it burning a little dark, instead of stop, regenerate gcode, etc. Just turn the pot down a little)
    Note until your pot comes, you'll want to tie IN to 5v (Laser PSU should have a 5v out you can use)
