57 Series Stepper Motor
Discussion in 'Motors' started by GRMark, Aug 2, 2024.
  1. GRMark
    GRMark New
    Had one of my Nema 23 motors going bad on my Open Builds machine using the original Black Box controller. It was the X motor and wasn't always coming back to the start position. I found that I was able to turn the shaft while power was being applied to the motor.
    I order several Nema 23's from Amazon. What was delivered was a somewhat larger (in length) motor and was labeled a "57 Series" motor. The specs were equivalent to a Nema 23 as close as I could tell. When I connected the new motor it did not work as expected. Wiring was correct and the 2nd motor exhibited the same operation. I did swap out one of the other Nema 23's and the Black Box ran it fine. Any ideas?
    Very unlikely to be the motor, more likely: docs:blackbox-x32:faq-identify-motor-coils [OpenBuilds Documentation] one of the 4 wires not making contact throughout
    Still sounds like wiring
