4X8 SHEET
Discussion in 'General Talk' started by BRIAN TYLER, Sep 4, 2023.
  1. BRIAN TYLER
    HAS ANYONE MADE A VIDEO ON HOW TO CUT A 4X8 SHEET USING THE TILING FEATURE?
  2. Alex Chambers
    Vectric have made a tiling video - does that help?;
  3. BRIAN TYLER
    Any chance is there one of using the actual machine? I think I got this part figured out but not sure how to make it happen on the machine
  4. Alex Chambers
    If you google "tiling on cnc" you will get a lot of videos on the subject. One I found in the link below.
    When I do it I prefer to set a fence on the Y axis, take a skim off it to ensure it is truly parallel with the Y axis. Then make a mark on the fence at your workplace zero, and really accurately make a mark on the workpiece at the start of the second tile (and third etc). After cutting the first tile slide the workpiece so that the mark lines up with the workplace zero mark on the fence.
    Giarc likes this.
  5. Christian James
    Christian James Journeyman
    Also check out Peter's video here...
  6. Albert64
    Albert64 Well-Known
    Have you considered using registration pins? Integrate them into the design and the worktable. I have used them successfully to engrave a 4' x 8' panel on my LEAD1515.
