3 or 4 wheels on X and Z axis
Discussion in '3D printers' started by Aleksandar, Apr 28, 2019.
  1. Aleksandar
    I am planning to replace linear rods with Vslots on X and Z for time being.
    Are wheels much smoother than rods and are the really precise as advertised? I know most recent chinese printers are using them.
    Did you go with 3 or 4 wheels per axis.
    The plan is 3 on Z x2 and 3 on X axis for hot end.
    I believe 3 wheels is easier to adjust than 4.
  2. Mark Carew
    For a 3d printer I would suggest 3 wheels with one eccentric for adding preload. You can use a plate like the V-Slot 20mm plate. This will work on the 20mm side of any of the V-Slot profiles and can have 3 or four wheels and the use of delrin Solid V Wheels as they will run much smoother then the Xtreme Solid V Wheels which would be overkill for a 3d printer.
    MFCarew and Aleksandar like this.
