110V 1.5kW Spindle maxing out at 12400RPM
Discussion in 'General Talk' started by brrian, Apr 23, 2022.
  1. brrian
    brrian Well-Known
    I'm setting up a 1.5kW, 110V, 24000RPM spindle and the HY01D511B VFD Controller. I followed the directions & settings in Josh's thread - the only difference is that I have PD001 set to 0, as I haven't connected to the Blackbox yet and want to test the spindle. Using the knob on the VFD spins the spindle up but it maxes out at about 12400RPM - just under half of its 24K max. I've triple-checked settings... everything else is correct. I should be able to get 24K 'from the knob', right? If so, any ideas what might be wrong? Thanks...
    Might be Motor Poles parameter (2 vs 4 pole)
  3. brrian
    brrian Well-Known
    My motor is 2 pole - I checked PD143 and it was set to 4. I changed it to 2 and... no difference.
    I decided to start fresh; reset everything w/ PD013 (8), then entered everything again & got the same thing again.
    Stumped. I'm sure it's something simple I'm missing.
  4. that-jim
    that-jim Journeyman
    brrian and Peter Van Der Walt like this.
  5. that-jim
    that-jim Journeyman
    You might look at PD 70 the settings are different for using the onboard control and using the 0-10 input.
  6. brrian
    brrian Well-Known
    PD70 was it! Thank you!
    that-jim likes this.
