1050 with Fusion 360 need a tutor for an hour or 2 in Los Angeles
Discussion in 'General Talk' started by Mike Nieman, Nov 4, 2020.
  1. Mike Nieman
    I am new to the CNC world. I built the 1050 and use Fusion 360 but my output is not what I thought. Either its my build or the options in Fusion 360. I am trying to engrave text in wood but it looks bad. Where can I find someone in Los Angeles to show me where I am going wrong? I am in the South Bay but could came to you if I can bring my machine. I attached a Fusion 360 file that I created.
  2. sharmstr
    What looks bad about it? Pictures and details on what post processor and your processor settings would be helpful. The only thing that sticks out to me is your 1.5mm depth of cut. Thats pretty deep for an engrave.
  3. Mike Nieman
    Shawn, thanks for replying. Attached is the wood carving which I think looked like scribbles. Not sure which preferences I should post. Openbuilds Control does not have any options that effect quality. Fusion 360 has so many options not sure what to send.
  4. sharmstr
    That doesnt look like a fusion problem. That looks like something is loose on your machine. Try something simple like a circle and report back the results.
  5. Mike Nieman
    Shawn, I think I just found the problem. my Y is not moving as free as it should and I think I need to figure out why my wheels are so hard to turn. Thanks for your help and I will update you once I fix this.
  6. rscamp
    rscamp Well-Known
    FWIW I loaded your model and simulated the cut. It profiled the letters to the specified cut depth instead of plunging the cutter to occupy the full width of the variable width characters. I discovered this happened because the bottom height was set to a very small value delta from the top surface. I changed it and the engraving now looks proper. I'm not sure it is a good idea to use such a slender cutter for engraving though... See pics attached.
  7. rscamp
    rscamp Well-Known
    Rest assured your machine can do it, Mike. This sample was made on my Workbee 1050. I think I used a 60 Deg. V bit in this case...
  8. Mike Nieman
    Rscamp, thanks for the info. I will try it. I thought my -1.5mm was the depth of my cut. Is there a chance of sharing your fusion file?
  9. rscamp
    rscamp Well-Known
    File attached.
    Basically, -1.5mm is a shallower DOC than the engraving requires in your design. I increased it to 10mm to be sure it was deep enough. Another suggestion - I wouldn't add additional stock when doing engraving. I removed the added stock from your Manufacturing setup. I think you want to engrave based on the material's actual top surface. Added stock material height would falsely enlarge the real character width.
  10. Mike Nieman
    Rscamp, THANK YOU so much for the valuable info.
  11. Mike Nieman
    I did the attached Os to check how clean it could do circles but it still looks like scribbles. I also attached the Fusion file that I inserted the SVG of a upper O and lower o. Sorry I could not figure out how to do a clean circle in Fusion yet. Importing an SVG is the best I could do right now. Any help to tell me what I am doing wrong would be greatly appreciated.
    Mike
    rscamp likes this.
  12. rscamp
    rscamp Well-Known
    Mike. I loaded your f3d file. As before, because of the shallow bottom depth specified it is tracing the outside of the "O"s (see attached) rather than engraving the letters. But this is obviously not your biggest problem.
    There are people here with a lot more experience than I troubleshooting the Openbuilds machines, but I would suggest some or all of the following:
    1. Your machine appears to be wandering aimlessly because of a mechanical problem. It appears unable to hold path due to tool loads. Grab the tool head (router or spindle) and force it hard by hand in each +/- X, Y and Z axis while the machine is powered on but stationary. If there is any play at all at the head or along the axes then the machine needs some serious mechanical attention before considering anything else.
    2. Do an air cut and observe the motion. It must appear to move exactly as per the simulation in Fusion.
    3. Try material that is easier to machine first. This follows 2. Pink insulation foam boards from Home Depot make good prototype material.
    4. Check the cutting bit. Is it blunt at the bottom? (It seems to be cutting a flat bottom rather than a "V" although this could be because the cutting head is loose and the bit is wandering.)
    5. Check the speeds and feeds, although they look reasonable to me at first glance.
    6. Check the stepper driver current setting per the documentation.
  13. Peter Van Der Walt
    Staff Member Moderator Project Maker Builder Resident Builder
    Mechanically something is very loose
    - check eccentric adjustments on wheels
    - check grubscrews on all shaft couplers (motor and leadscrew ends both) and liberally loctite them.
    - check stop collars are tight up against the bearings
    - same for any pulleys if you have belt driven axes. Check and locktite pulley grubscrews so they dont slip on the motor shafts
    - tension belts properly
    - if you have belts, dont forget the cable ties that stop them slipping out of the holders.
    - check all fasteners
  14. Mike Nieman
    Peter and rscamp, I want to THANK YOU both for all your help. It was a loose connection with my stepper motor on one side of my Y. I think I am OK now.
    Mike
    rscamp and Peter Van Der Walt like this.
  15. rscamp
    rscamp Well-Known
    Glad you got it sorted!
