Цель движения G-кода превышает ход машины
Discussion in 'OpenBuilds Bug Report' started by dim135245, Nov 6, 2022.
  1. dim135245
    dim135245 New
    БУДИЛЬНИК:2
    Цель движения G-кода превышает ход машины. Положение машины надежно зафиксировано. Сигнализация может быть разблокирована. (Щелкните правой кнопкой мыши кнопку «Устройства», чтобы сбросить соединение)
    На или около линии 2:
    Поток завершен в 0:00
    [MSG: Сбросить, чтобы продолжить]
    Ok
    Grbl 1.1f ['$' за помощь]
    [MSG:'$H'|'$X', чтобы разблокировать]
    [MSG:Внимание: разблокировано]
    Ok
  2. Alex Chambers
    In English please.
  3. Christian James
    Christian James Journeyman
    google translation...
    ALARM CLOCK:2 G-code move target exceeds machine travel. The position of the machine is securely fixed. The alarm can be unlocked. (Right click the Devices button to reset the connection) On or near line 2: Stream ended at 0:00 [MSG: Reset to continue] Ok Grbl 1.1f ['$' for help] [MSG:'$ H'
  4. Alex Chambers
    @dim135245, we are going to need a bit more information. If this is happening at the start of a job did you home your machine before starting the job? - not homing is a very common cause of this problem.
    If that's not the cause of the issue we need to know what software you used to prepare the file - upload the design file AND the g-code file so that we can have a look at them.
