Hello.
- Machine Type:
- Other Machine
- Vectric Aspire
- Electronics:
- Other Controller
- End mill 6mm
Today I present a cube that contains three other cubes.
The construction was made of wood dimensions 58mm X 58mm X 58mm.
The base for the cube was made of different types of wood glued to have a thickness of 16mm.
The first three photos show the base of the cube on the CNC for machining.
The next two photos show the support at the angles between the cubes that is created and the gaps that are created between them on each side.
The last photo shows the design and dimensions of the cube.
After finishing all the pockets on each side, then with a small knife I carefully cut the fasteners on all three sides.
A little rubbing and finally.
I hope you like it.
