Intermediate Reason Bases (βάσεις Ρεσώ)
Rating:
4.5/5,
  • Software:
    Vectric Aspire
    Bit or Laser Size:
    EndMill 8mm , Roundover 12mm
    Materials:
    Greek walnut (Ελληνική καρυδιά)
    Translation:
    The machining of the pieces was done in my small, self-machining CNC, in which I set up a fourth shaft on the table and turned it into a lathe. Before rounding the wood I open a hole 42 mm x 15 mm to accept the tap. After rounding the wood I open three rivers as in the photo and then with the Roundover cutter round the edges into the rivers. The big piece is 160 x 54 mm while the small 120 x 54 mm.
    Η επεξεργασία των κομματιών έγινε στο μικρό μου ιδιοκατασκευής CNC στο οποίο προσαρμόζω στο τραπέζι έναν τέταρτο άξονα και γίνεται τόρνος.
    Πριν στρογγυλέψω το ξύλο ανοίγω μία τρύπα 42 χιλ. Χ 15 χιλ. για να δεχθεί το ρεσώ.
    Αφού στρογγυλέψω το ξύλο ανοίγω τρεις ποταμούς όπως στην φωτογραφία και κατόπιν με το Roundover κοπτικό στρογγυλεύω τις ακμές στους ποταμούς.
    Το μεγάλο κομμάτι είναι 160 χ 54 χιλ. ενώ το μικρό 120 χ 54 χιλ.
  1. MaryD
    Congratulations @rokasni ! This project was featured in the May 21, 2018 edition of the OpenSource Daily News.
  2. rokasni
    Translation: My friend is from Greece and I live in Halandri, Attica. Unfortunately, I do not know English and communication is with the Google translator. For the project I did not upload it by mistake because I thought it was simple. I upload the drawing to a DXF file. This design has a diameter of 52.5 mm and a height of 115 mm.
    1) First I create with the Gadgets Wrapped job setup in Vectric Aspire the dimensions I want. This will create the surface that I will process.
    2) Then with the Greate Rounding Setup on Vectric Aspire, the toolpath will be created to round the wood.
    3) I create the three Pocket vectors at a depth of about half the diameter (52.5 / 2 = 26mm).
    4) With a Point Cutting Roundover 12mm cutter creating a Profile on a depth similar to the cutter eg. 6mm.
    5) Finally, run the three toolpaths in the order they were created. I hope I helped . For any questions I am at your disposal.
    Φίλε μου είμαι απο Ελλάδα και μένω στο Χαλάνδρι Αττικής.
    Δυστυχώς δεν ξέρω αγγλικά και η επικοινωνία γίνεται με τον μεταφραστή του Google.
    Για το σχέδιο δεν το ανέβασα απο λάθος μου γιατί θεώρησα οτι είναι απλό .
    Ανεβάζω το σχέδιο σε DXF αρχείο.
    Το συγκεκριμένο σχέδιο έχει διάμετρο 52,5 mm και ύψος 115mm.
    1) Πρώτα δημιουργώ με το Gadgets Wrapped job setup στο Vectric Aspire τις διαστάσεις που επιθυμώ.
    Αυτό θα μου δημιουργήσει την επιφάνεια που θα επεξεργαστώ.
    2) Κατόπιν με το Greate Rounding Setup στο Vectric Aspire θα δημιουργηθεί το toolpath για να στρογγυλέψω το ξύλο.
    3) Δημιουργώ στα τρία διανύσματα Pocket σε βάθος περίπου το μισό της διαμέτρου ( 52,5/2=26mm).
    4) Με ένα κοπτικό Point Cutting Roundover 12mm δημιουργό ενα Profile on σε βάθος ανάλογο του κοπτικού π.χ. 6mm.
    5) Τέλος εκτελώ τα τρία toolpath με την σειρά που δημιουργήθηκαν .
    Ελπίζω να βοήθησα .
    Για οποιαδήποτε απορία είμαι στην διάθεση σας.
      Mark Carew and Gaou² like this.
  3. Gaou²
    TRANSLATION:
    my lovely friend. it would be good after you upload the objects to load the projects so that other users can do it. also because you are not writing English;
    Be well. where you are allowed (Greek area.)
    ωραιος φίλε μου. θα ήταν καλο αφου ανεβάζεις τα αντικέιμενα να φορτώσεις αι τα σχέδια ώστε οι αλλοι χρήστες να μπορέσουν να υλοποιήσουν . επισης γιατι δεν γράφεις αγγλικά ?
    Να εισαι καλά . απο πού εισαι αν επιτρέπεται ( περιοχή ελλαδας.)
      rokasni likes this.
  4. Mark Carew
    Really cool! If you could share the file that would be great
      rokasni likes this.
  5. MaryD
    Beautiful!
      rokasni likes this.
    [email protected]
  • Follow us on Instagram
    Donate to Open Source
