OX vs Workbee, what's the difference?
Discussion in 'CNC Mills/Routers' started by laurent Besseas, Jun 12, 2020.
  1. laurent Besseas
    Hello, I'm wondering, in terms of feature, what are the main difference between theses 2?
    - Maximum work area
    - Accuracy
    - Milling capacity (speed, type of material, pass thickness...)
    Ox: outdated, long ago's design
    Workbee: Next gen
    LEAD1010 is actually the class leader
    - Entirely modular
    - High Z mod
    - More rigid
    - Several factors more acuurate than an Ox
  3. laurent Besseas
    Thanks,
    so LEAD1010 is the best, but limited to 100x100x? (workbee is 150x150x47mm).
    At this time yes
    Bigger is not always better: See How to calculate V-Slot® deflection - the bigger you go, the more the deflection
    What do you want to make? Milling lots of Alu little widgets: Get a Minimill (super rigid) for example ... Only planning on doing somewhat precise plywood sheet jobs like furniture and signs, get a 1500x1500...
  5. laurent Besseas
    In my case, I'm looking for a model where I can add a 4th axis to work on 140x140x140mm stock wood material. I was looking for CNC Turning machine but it is lot more expensive than DIY CNC.
    Ok cool, well look at the limitations above, Workbee is still on the list. But the info should give you some idea of the pros and cons.
  7. Alex Chambers
    Big drawback for the workbee with 4th axis is Z height. It has been suggested that the high Z mod for the Lead 1010 will fit the Workbee, but then it fits the Lead 1010 anyway. :D
  8. laurent Besseas
    Thanks,
    Then the only one remaining is the Lead CNC with extra z as there is no extra Z mod for the workbee. Surprisingly there is no true openbuild CNC Wood Lathe
  9. Alex Chambers
    There are high Z mods for the workbee - taller plates for example.
  10. laurent Besseas
    Thanks, not on openbuild shop I'm afraid.
  11. Giarc
    I am in the process of building one right now based on purchasing a LEAD High Z kit and all off the shelf components from Openbuilds. The only thing purchased elsewhere is the rotary axis and tail stock. It will have a cutting length of about 27" and cutting height of about 10." The length could be longer, but I only have Vcarve desktop so I can't do unlimited.
    Rick 2.0 and Peter Van Der Walt like this.
  12. laurent Besseas
    Exactly what I would like to do. Would you lilke to share the component please for the rotary and tail? Thanks
  13. Giarc
    I purchased it from Ebay in the U.S. form a store that - I assume - imports them in bulk from China. 〖US〗Rotation A Axis CNC Router Rotary Table 4th Axis 100mm 3 jaw chuck&Tailstock | eBay My previous attempt to get one a year ago failed when the Aliexpress seller took my money then said I had to pay more because shipping rates went up. That was a month after they had taken my money. I disputed it and I got my money back. I will not do business with them again. That Aliexpress store was LYCNC Store. I would have preferred a 4 jaw chuck, but I was not willing to pay the significant difference in price. I plan to make a triangular end piece out of aluminum that will screw into my work piece for the jaws to grab.
  14. laurent Besseas
    Thanks, will a nema23 be powerfull enough to be used as Lathe axis? Same question apply to the belt drive....Please be aware that I'm not a mechanic man, so my question may sounds stupid.
