Newbie question about Control simulation rendering
Discussion in 'Control Software' started by darrepac, Apr 20, 2020.
  1. darrepac
    darrepac New
    Hi
    I am trying the whole chain of making a first project.
    I have managed to make the design under Fusion 360 and generate the GCode from it with GRBL post processor (thanks to explanations here).
    I was a bit confused with feed rate settings in Fusion but I think I managed it and now I am simulating the cutting into CONTROL software and I have something weird in the some parts of the cutting: the curved ones.
    I don't know why (I mean I see no reason in terms of speed setting) but in the simulation it is making the curve very fast contrary to straight lines.
    I am wondering if it is just a side effect of CONTROL having more difficulty to calculate curve or if what I see is really what I will get on my machine.
    I upload the GCODE file and the first curve where CONTROL is going very fast is the line:
    G2 X143.524 Y203.009 Z-10 I57.063 J-18.541 (line 47)
    Side question: it is not easy to find which line is doing what in CONTROL (may-be the number at the bottom right of the window is the solution but I could not find the link between this number and the line number in GCODE). So I end up using other software which was able to go line by line in the GCODE and show the resulting movement.
    thanks
    Simulation is 'best effort' and will run fine on the machine itself.
  3. romamaker
    romamaker Well-Known
    Did you know that Fusion can run a simulation for you as well? And it can handle more complex cuts that can make the Control simulation puke.
  4. darrepac
    darrepac New
    Yes I saw the simulation in Fusion but then I generate GCode and saw the result in Control and I was surprise but the curves so I thought it could be a GCode issue
    (; ouch lol
    I'll see if I can add the "tweening" (the part the makes the sim "flow" from point to point, to the G2s it had trouble with
    v1.0.234 or later (not released yet) has some improvements to the SIM now :)
    - Follows the arcs with the set feedrate
    - Doesnt decelerate/accelerate to/from 0mm/min between sections (machine would also continue smoothly)
    - Added the gcode line indicator to follow the cone (was in there a while back, had a bug and wasn't showing)
    GIF showing it in action (on your test Lamps file)
  7. Alex Chambers
  8. darrepac
    darrepac New
    Impressed by the reactivity...but take care, I am just starting ;)
    :) We try :) - refer changelog and commits :)
    Also, 1.0.234, fixes the Right-click menu in the Gcode editor (simulate from now start at the line you select - wasnt working for a while) and added a "Simulate ONLY line xxx" - useful for checking a single line of gcode
  11. romamaker
    Apologies! No offence intended! Control works find most of the time, but when I moved to Fusion 360 for CAM to do some 3D cuts, I ended up with some much larger, complex g-code that the simulation in Control just couldn't quite handle.
    :) none taken :) I even quoted your post selectively out of context to make the Ouch joke with :)
    And... it got me off my behind, and on to fixing the tweening at last :)
  13. Alex Chambers
    You stand up when coding @Peter Van Der Walt? :ROFL::ROFL:
    Giarc and Alex Chambers like this.
