Open Rail Build
Discussion in 'CNC Mills/Routers' started by ian carfagna, Oct 27, 2014.
  1. ian carfagna
    ian carfagna published a new build:
  2. Serge E.
    Serge E. Journeyman
    Interesting. As your machine evolves, it should get more and more precise ...
    Not certain how stable the MDF will be over time : environment (ex: moisture, temperature) and machine movement (ex: vibrations).
    It also depends on the type of work you aim to do, as well as speeds ...
    Where there is a will, there is a way.
  3. ian carfagna
    Yes Serge, I plan to replace the MDF with parts cut from the Machine once its finished. First will be the Gantry Plates. I realize the vibrations are going to cause stress on the wheel holes, and it will get sloppy after a while.
  4. GrayUK
    Hi Ian.
    Check out Slyclockwerkz's Plates. Cheap, but definately worth the price.
    Gray
  5. ian carfagna
    Thank you Gray, but my plates are custom, only because i have a modified design.
