GBRL not working need help
Discussion in 'CNC Mills/Routers' started by lexi chambers, Jun 23, 2019.
  1. lexi chambers
    hi all i am having problems with my system i get a error message T1-M6 see picture when using open builds control, universal gcode sender, and ugsplatform nightly version, im using fusion 360 doing a simple face and a 2d adaptive clearing but the system pauses and gives the error when i run the gcode, the only difference is with openbuilds control i can do the integrated flattening/surfacing tool it works so i know the cnc is set up properlyand is working there is just something wrong in the code that these softwares dont agree with but cannot find what the problem is
    i did download source rabbit and everything is fine it accepts gcode from fusion no problem, i want to use openbuilds control or ugs platform as i like the interface etc but i need to get to the bottom of this problem anyone have any ideas
    im a newbie so please be gentle with me :) any info would be much appreciated
    my full spec of machine
    workbee cnc
    arduino uno
    tb6600 drivers
    if you need anymore info on my sysme let me know
    many thanks
      File size:
      143.7 KB
      10
      File size:
      191.9 KB
      10
      File size:
      79.2 KB
      10
  2. sharmstr
  3. lexi chambers
    so just delete t1 m6 before i save the post?
  4. sharmstr
    If you mean "before you save the gcode", then yes :)
    Keep in mind that you'll probably run into other errors down the road and you should really take my advice and change your post processor.
  5. lexi chambers
    ok ill download it thanks for the info :) ill let you know how it goes
  6. lexi chambers
    when i click the first step i.e. setup and use personal post library i copy and paste the link into file explorer and the folder is blank, also when i click setup and click use personal post library the box in the bottom right (property is blank and the post button is unable to be clicked
    does anyone know what file type openbuilds control uses? im using a nc file at the moment
    Its not OB control that doesnt like your gcode.... Its Grbl.
    Grbl Only understands some gcode words.
    Fusion is outputting words it does not understand
    When you use a Grbl compatible Post Processor it outputs just words that Grbl understands, therefore, dont overthink it. Install Swarfers Grbl Post Processor and use that, no other plans needed. Thats the one that works
  8. lexi chambers
    hi all it works yay!! i had to do a few more steps that wasnt included in the instructions but i worked around it to make it work i might have to actually do a post for this as for a complete noob like myself its kinda complicated and i got lucky as i guessed the files i needed and where to put them had to do some things with fusion and the cloud etc
    thank you sharmstr & Peter Van Der Walt for the info you are amazing !!!!!!!
  9. Željko Mišković
    Hello everyone. Since I had just sailed into the waters of CNC work, mostly related to PCB prototyping using the excellent FlatCam program for G-code preparation, I encountered a bizarre problem. Namely, it is unclear to me why the F06ware "OBC" does not have built-in support for the command M06-stop machine (pause) due to the replacement of drills or other processing tools. Alternatively, manually adding commands and bringing the X-Y-Z to zero and stopping in that position can achieve the desired, but this is not a practical solution. I ask developers to incorporate this option in future editions of the application. Best regards from Croatia, Željko Mišković, B.Sc. el. techniques.
    Grbl doesnt support M6. But see Toolchanges · Issue #26 · OpenBuilds/OpenBuilds-CONTROL
    Alex Chambers and sharmstr like this.
